Badcaps.net Forum
Go Back   Badcaps Forums > General Topics > General Capacitor Questions & Issues
Thread Tools Display Modes
Old 01-18-2018, 05:43 AM   #1
MagicSmoke
City & State: Perdido Beach, Alabama
My Country: USA
Line Voltage: 120v AC 60Hz
I'm a: Knowledge Seeker
Default JVC tv Power Supply Caps Question
Received a free JVC tv, would not power on. Testing revealed startup cap for stby volts bad, a 1uf 50v Lelon electrolytic. Replaced the one cap and all is good, tv now works.
My question is would it be a good measure to replace all of the caps on the psu, it has a mixture of Nichions and Lelons for more longevity? It was manufactured in 2008.
MagicSmoke is offline   Reply With Quote
Old 01-18-2018, 06:39 AM   #2
Andrew F. Ali
Andrew F. Ali's Avatar
City & State: Point Fortin
My Country: Trinidad & Tobago
Line Voltage: 125VAC 60Hz
Default Re: JVC tv Power Supply Caps Question
If you have an ESR Meter you could probably check ALL the e-caps on the PSU and if they are doubtful then replace them, as preventative maintenance. However, if your set works why interfere with it, running the risk of cracking joints, installing caps wrong, shorting joints or breaking the board. My advice, Let sleeping dogs lie.
Andrew F. Ali is offline   Reply With Quote
Old 01-20-2018, 10:44 PM   #3
sam_sam_sam
City & State: Sunny Jacksonville FL
My Country: USA
Line Voltage: 120 Volts 60 HZ
Or you take the view that any cap that under 100uf replace it just because the small diameter caps dry out faster than the bigger ones do
Now if were me and the caps brands that have a tendency to be bad and ones that you replace on site when you see them ( Lelons ) for me this is a brand when I see them I replace them
Most of the time I just recap it and be done with it
But I would not be in a hurry doing this job for the reasons given by Ali in the post above
__________________
9 PC LCD Monitor
6 LCD Flat Screen TV
1 Dell Mother Board
15 Computer Power Supply
All of these had CAPs POOF
sam_sam_sam is offline   Reply With Quote
Old 01-21-2018, 12:10 AM   #4
MagicSmoke
My Country: USA
There are only 5 of the Lelons on the board. The rest are Rubycons, or UCC.
I think I will replace the lelons and leave the others alone. Have done other cap replacements so no problems there. Thanks.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2020
Powered by vBulletin ®
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
