I have trouble with this psu, l'm suspecting pwm ic is the problem, but i can not find it's datasheet, or anything. The picture is from service manual of tp.ms3463s.pb801, mine board is pb782, l'm guessing it's similar, if not exact as mine.. So what is UB101?
Identifying IC & troubleshooting TP.MS3463S.PB782
Re: Identifying IC & troubleshooting TP.MS3463S.PB782
Here is what I found
https://www.yoycart.com/Product/534309773654/
But could not find the data sheet for it
It might not be what you are looking for I do not knowLast edited by sam_sam_sam; 06-13-2019, 06:23 PM.9 PC LCD Monitor
6 LCD Flat Screen TV
1 Dell Mother Board
15 Computer Power Supply
All of these had CAPs POOF
It looks like a LD7536RM, I think I found the correct one.Attached FilesLast edited by R_J; 06-13-2019, 07:51 PM.
Originally posted by R_J View PostIt looks like a LD7536RM, I think I found the correct one.
Replaced it, 15V was not steady, no stb power or 12V rail.. Changed optocoupler, and diode on secondary side of optocoupler, you have red cicled on pic what was changed. Anyway, it's working now, thank you for leading me to another succesfull job
TV tuner seems to cant find any channels, i guess thunderstorm fried tuner too?
Well I am glad you were able to fix it great job9 PC LCD Monitor
1 Dell Mother Board
