HP DV6 2130ec
    Re: HP DV6 2130ec
    sorry chrle, I do not have any schematics. maybe you can check the datasheet one by one. see that for power 3v/5v.
      Re: HP DV6 2130ec
      Francisco.s
      Sir i flashed bios but still no change on and off within 1sec
        Re: HP DV6 2130ec
        Originally posted by ravi_1617 View Post
        Francisco.s
        Any of the posted schematics match your motherboard?
        It is very important to get the schematic diagram in order to have some references.
          Re: HP DV6 2130ec
          After reprograming same condition on&off in 1sec.
            Re: HP DV6 2130ec
            sir is it HP_DV6_lx86 i think but image same as 4 images it has ati redeon graphic chip and 2 amd /ati north and south bridges
              Re: HP DV6 2130ec
              It is very difficult to repair this kind of problem without a schematic.
              Bios are well known problems in HP motherboard, BTW, how about 3/5 volts pwm circuits?
                Re: HP DV6 2130ec
                sir i will cheak and let u knows thanks
                  Re: HP DV6 2130ec
                  well got same issue , and the schematic not helping , trying to find pq27 and not finding it , and it exist on board
                    Re: HP DV6 2130ec
                    well find it , here it is i hope it help you guys
                      Re: HP DV6 2130ec
                      you didn't see it bro? near cpu socket if i have the right image (i hope)
                        Re: HP DV6 2130ec
                        measure resistance to ground on all big coils and on capacitors on GPU. search for resistance 4ohm and lower on both sides
                          Re: HP DV6 2130ec
                          meritosari , pq27 i was finding im on the board , but not on the schematic you guys have showed on the thread .. so i found the correct schematic and i added it here
                            Re: HP DV6 2130ec
                            Thank you very much.
                              Re: HP DV6 2130ec
                              Same problem as above here: mobo will turn on for a split second.
                              I have also noticed a pattern:
                              1st attempt to 5th attempt: the mobo powers on a little bit longer each time (fan spinning longer)
                              On 6th attempt the caps lock led will also turn on.
                              Then the pattern resumes to 1st attempt behavior and so on.
                              What can it be?
                              Please note that I have flashed the BIOS and it changed nothing :/
                                Re: HP DV6 2130ec
                                What can it be?
                                when you say fan spinning longer caps lock led also turn on does the Mob go to BIOS ? how did you flashed BIOS and how many BIOS did you try ?
                                  Re: HP DV6 2130ec
                                  TLDR: I give up on that MB
                                  Hello techtiger
                                  - when fan is spinning longer, it spins for about one second max
                                  - the longest time the PC is powered up is about one second, then no power. No BIOS access.
                                  - BIOS chip removed from board and flashed successfully with CH341A. One version only was used (found on badcaps : "Hewlett-Packard-F.13.rom").
                                  I have a HP DV7-3005sf with motherboard DAUT1AMB6E1 REV:E. AMD processor. ATI video. AMD north and soutbridge.
                                  I bought that PC second hand. At first it had that 1-second-shutdown behavior. I disassembled it, tried a combination of replacement RAM, replacement processor and eventually the laptop stayed on, fan spinning but black screen, no picture, no backlight, no VGA signal. Tried quite a few times and the laptop stayed on with black screen.
                                  Since the screen is cracked, I wanted to test another screen. The day after, I vaguely recall putting the original CPU or something, not too sure what I did. But from that day on, the MB, again, won't turn on for more than one second.
                                  Update: as I was writing those lines, I tried a desperate move. I removed the CPU to see the behavior without it. Same 1-second-shutdown. But now that I have the CPU inserted again, no boot at all. Just the led on the power jack blinking. I give up on that mobo.
                                  Thank you for your time.
                                    Re: HP DV6 2130ec
                                    Hello techtiger
                                    then try a mild reflow of graphics chip. have seen a lot of them failing,try with a another working AMD processor , test resistance to GND all the Big Gray Coils with out power
                                      Re: HP DV6 2130ec
                                      Yeah probably the northbridge, RS780M or RS880M fail a lot. Heat can indeed make them work for a short time, no need to reflow just 200°C is enough. It has to be replaced as it will fail again very shortly.
                                        Re: HP DV6 2130ec
                                        Thank you
                                          Re: HP DV6 2130ec
                                          you can see your chipset
