DA0LX8MB6D0 REV:D HP DV6 BIOS & help
    Pavilion dv6
    DA0LX8MB6D0 REV D
    SIO KB3926
    NB: 216-0752001
    GPU: 216-0774007
    CPU: Turion II
    Hi guys
    got here a problem with this MB da0r75mb6cd0 REV: D not turn on
    Need bios
    check +19V Ok
    check+ 3.3V +5V VPCU oK
    check PWBT 3.3V ok
    check SIO +3VPCU OK
    After pressing PWBT RSMRST 3.3V OK but when releasing PWBT 0V
    EC PIN 98 SUSON 3.3V After pressing PWBT but when releasing PWBT 0V
    EC PIN 101 S5 ON 3.3V After pressing PWBT but when releasing PWBT 0V
    EC PIN 34 VDDAEN 3.3V After pressing PWBT but when releasing PWBT 0V
    need help what to check ?
    thanks in Advance
    Re: DA0LX8MB6D0 REV HP DV6 BIOS & help
    The referenced link is not correct. The correct one is in the following post:
    https://www.badcaps.net/forum/showpo...43&postcount=3
    In addition, you should measure RSMRST and SUSON before pressing the power button. measure pins 2,37,122,123 of SIO.
      Thanks Caspian again sorry for Schematic link i will measure RSMRST and SUSON before pressing and post reply soon
        the Voltage are
        PIN 2 0.0v
        PIN 37 3.23V ECRST
        PIN 122 0.40V CRY1
        PIN 123 1.59V CRY2
        can you enplane how Crystal gets power & signal is it SIO chip ?
        i have test with VICTOR VR2000 Crystal checker signal fluctuate 30.xxxkhz and keep changing not stable
          you forgot to measure RSMRST and SUSON. Probably, you should reprogram KB3926. But I am not sure yet.
            RSMRST 0V
            SUSON 0V
            With out pressing Power On
            I don't have the SIO reprogram (KB3926)
            So I will replace the SIO & let you know
            Thanks Caspain again for the support
              but I am not sure about KB3926 yet.
              I never replace big ICs before I get sure about the cause of the problem. That is because of the facts that replacement of big ICs takes a lot of work and it is costly and risky, and in addition, the replaced IC might be healthy.
                ok i got you until sure about the exact problem not to change can you recommend a SIO reprogrammer to buy
                  first check how many bios ICs exist on the mainboard. If it is only one, make a backup and upload it here. Then reprogram the bios chip using another bios dump.
                    check the MB only 1 BIOS ICs exits on the mainboard. backed up BIOS i have uplode it here , i coudent find another bios dump !
                      try the bios provided in the following thread. it belongs to HP Pavilion Dv7, but it may work.
                      https://www.badcaps.net/forum/showthread.php?t=52554
                      Bios dump of DA0LX8MB6D0 is available on non-free websites but it is very cheap.
                        Mainboard came back to life it's working again the BIOS was the problem
                        Thanks CASPIAN Again and sharing Your Knowledge
