Re: The Great Capacitor Showdown - Rubycon vs Panasonic vs Samxon
Well, Chris1992, it get beyond just that. I also have it worked for the 8 months with bridged Vcore caps with 100nF SMD ceramics, witch cause unusualy high overheating and overstressing on the caps. Usualy even with 6 Vcore 2200uF Panny FM machines is doing such thing resulting in immediate unstable operation. But the Samxons hold even with THAT situation. They must be pretty good, if you ask me.
Anyway, about the sis JetWay V266B once again - I would like to say something that partly not belong in this thread and partly it does - altrought the stability of her machine is 100% (never crash or fail once (!) ) and no Prime stress testing could show any weakness, it do frequently not correctly DMS power off the monitor after the set 10 min of inactivity and 4 or 5 times it failed to power up when I provide from external switcher the main voltage to the PSU.
While these problems for nearly now 9 months of usage with folding all the time (recapped around 3. 20. 2006) aren't serious, I was still convinced that I could get rid of them by replacing the small 10 and 22uF caps, witch I did not before, as I don't have any suitable caps around 22uF to do the job...
But I wanted to exchange them, so about week ago, when I got 22uF 35V RS Samxons from Big Pope, I did it. The immediate impulse was, the the mobo for the last time failed to power on, and for this time, reset not fixed that. So obviously as I suspected, having a old caps with GSC letters on sides are't good, even they are small...
I recapped the remaining 16 pcs of mixed 10 and 22uF ones with these Samxons RS 22uF 35V caps.
Results.
After 30x power on's for test it yet failed to show any failure. I will post ASAP in the JetWay V266B thread to notify when the mobo stop post after providing the power (bios settings say kick on on power on) just once more
After over 50x testing it once again failed to fail to DPMS power off the monitor, as it did before. Excelent
Conclusion.
Recapping even the smallest electrolyte caps from inferior brands aren't voluntary but matadory. Especially on oldie boards, such as V266B or these KT7-R Topcat want to use for the cap's test.
Conclusion regarding this test.
If the small caps on these test KT7-R boards will not be exchanged to any reliable brand (Samxon, Rubycons, Panasonics...), the test will be simply invalid. It is not only my experience, but others as well, that indicating the necessarity of exchanging even small caps.
I will be just repeating myself there, however, since I already mention it strongly that state and progression of dying could be for the small caps different on each board, therefore replacement is matadory.
Results.
Conclusion.
