Re: Sony LD-65X850-8c vertical lines on display problem
The peel off one side is maybe an option, usually when it works, the tv has a good picture on the half screen with all good drivers, unhooking the tcon ribbon cables to panel one at a time and seeing if you get half a good screen, it's usually the outside ribbon cable. The peel off method is for tvs with tabs on the sides.
