Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Power Supplies and Power Supply Design
Thread Tools Display Modes
Old 01-10-2019, 05:32 PM   #1
jayjr1105
jayjr1105's Avatar
City & State: Lancaster, PA
My Country: United States
Line Voltage: 120VAC 60Hz
I'm a: Hardcore Geek
Default Delta DPSN-525AP Power Supply Repair
Hi all, this power supply is for a Cisco POE ethernet switch. It's 525watts and puts out two rails, 50v for the POE and I think 12v for the main logic board. When powered on, the 50V rail seems good but I get less than 1 volt on all the red wires coming out of the 14 pin connector (14 pin connector is only red and black wires).
Any recommendations to troubleshoot? I can't find a pinout or schematic but I see that there are basically 2 rails distributed.
https://prnt.sc/m5lwqq
http://prntscr.com/m5m6uh
__________________
Ryzen 2600X
16GB Corsair Vengeance 3200MHz
MSI Mortar Arctic mATX
MSI Vega 56
Acer 32" 1440P Freesync
Rosewill Capstone 750W
Hakko FX-888D Station
FX-8802 Iron
Chinese 63/37 1.8%
jayjr1105 is offline   Reply With Quote
Old 01-11-2019, 10:55 AM   #2
PeteS in CA
PeteS in CA's Avatar
City & State: San Jose, CA
My Country: USA, Unsure of Planet
Line Voltage: 120VAC, 60Hz & 115VAC, 400Hz
I'm a: Professional Tech
Default Re: Delta DPSN-525AP Power Supply Repair
I'm not familiar with this P/S, but it looks to me like there is a PFC stage, followed by two separate, individually regulated inverters (probably synced). So the fact that the -53 works indicated that the PFC works, but the 12V circuit is not, So your focus will need to be learning why.
I'd start first by looking at whether the 12V output is shorted. If it isn't and the output is literally zero volts, you need to find out why the controller is not switching. If the controller is on the primary side, you can't use a grounded oscilloscope.
__________________
PeteS in CA
Where might is right
There is no right.
- Sophocles in "Antigone"
All that is gold does not glitter,
Not all those who wander are lost;
- J.R.R. Tolkien, The Fellowship of the Ring
PeteS in CA is offline   Reply With Quote
Old 01-11-2019, 10:56 AM   #3
R_J
City & State: ☻
My Country: Canada
Start at the missing 12 volt output and trace the secondary circuit back. The voltage will come from diode off a transformer secondary, if there is no voltage on that diode, check the primary side to see how it operates, ie does it have proper voltage to the switching fet/s, is the drive ic getting vcc and is being turned on.
I could not find any schematic or even good pictures of the solder side.
R_J is offline   Reply With Quote
Old 01-11-2019, 11:03 AM   #4
jayjr1105
jayjr1105's Avatar
I'll try to get some high res photos on the back side when I get home.
Old 01-11-2019, 03:22 PM   #5
jayjr1105
jayjr1105's Avatar
Here's a good shot of the back
https://i.imgur.com/27K5XeK.jpg?1
Old 01-18-2019, 03:04 PM   #6
ktmmotocross
Boardkiller
ktmmotocross's Avatar
City & State: slovakia
My Country: slovakia
Line Voltage: 230VAC 50Hz
I'm a: Hobbyist Tech
try to heat up capacitors and checking for output voltage
ktmmotocross is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2019
Powered by vBulletin ®
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
