The four comm lines are all shorted together. At first I thought maybe the common mode chokes had shorted and that would be a coincidence in itself maybe but to have Tx shorted to Rx makes me think it's not the chokes at all.
The continuity tests were done with the lan/wifi daughtercard removed from the circuit and the Tx+/Tx-/Rx+/Rx- lines appear to run direct from the RJ45 connector (through the chokes) to the daughterboard connector. The schematic (included below) indicates the same thing.
The RJ45 pins are not bent or smashed up.
Is there something peculiar about these RJ45 connectors that something could be going on inside it ?
