Dead xbox one controller - 1ACMD short
    So I'm trying to repair this xbox one controller, and I found the the 3.3v regulator is shorted. The number on it reads 1ACMD, I cant find a replacement anywhere.
    I was hoping maybe someone on here could suggest a suitable replacement, in the UK preferably.
    Thanks in advance!
    Re: Dead xbox one controller - 1ACMD short
    Have you got a photo of the part ?
      I have it removed, but it is marked U3 in this pic
        gameboy-camera??
          Lol, sorry, I got that pic online on my phone. U3 in this pic.
            There is some reference here to a possible substitute http://forums.xbox-scene.com/index.p...and-info-1537/
              That's where I got the pic from, I read about the MP3414, but I wasn't able to find a source in the UK
                http://www.mouser.co.uk/Monolithic-P...Z6j76fZ1ysn703
                the spec sheet says this ic converts 1.8 volts in to 3.3 volts output
                  Is this it http://uk.rs-online.com/web/p/boost-converters/9175829/
                    Thanks for the links guys, as far as I know, mouser ships from USA. So I will probably go with rs-online.
                    Do you think that one will be suitable? I usually replace components with the same ones, I don't have a clue when it comes too substitutes.
                      Hello. Have you fixed your issue? I just got one in today with the same problem. The datasheet and part number you have is incorrect. This is the part number: mp2161gj. It should convert the incomming 5v to a voltage Microsoft predefines, with two resistors, as you can see in the datasheet. I have measured the resistances, made calculations, and output should be between 3 and 3.3v.
                        I did resolve the issue, but I used a donor board in the end.
