Cap question
    Cap question
    Hello all I need some info I have posted to photos of two caps the green is the defunct cap the black is the so called replacement,but different size,can it be used.
    Re: Cap question
    where did you get the black crap-cap?
      Re: Cap question
      Draw find eBay I think
        Re: Cap question
        Would it be up to the job ? Or need replacing a month down the line
          Re: Cap question
          You go by uf and voltage not the temperature get a good make replacement for example 100uf 16v you can go higher on voltage not on the uf
            Re: Cap question
            The are like for like but not in size
              Re: Cap question
              it may work, but cant say for sure without a datasheet.
              and that needs the makers name!
                Re: Cap question
                i brought some of those sd caps from ebay a couple of years ago, they lasted about 6 weeks on a tv inverter circuit before failing again, try and find a Panasonic replacement if i was you.
                  Re: Cap question
                  Both look nonpolar?
                    Re: Cap question
                    In the first picture you can see the polarity stripe on both caps. And yes it will work, for how long... Let us know. Or use a name brand like Panasonic if you are worried.
                      Re: Cap question
                      Trash-can them!
                      A good 99% of the caps sold on eBay are either cheap no-name junk like this or counterfeits of big-name brands like Nichicon, Chemicon, and Sanyo/Suncon. Just get some caps from one of the big online component distributors (RS, Farnel, Mouser, Digikey, Badcaps.net, or even member Behemot here).
                      Go with either Panasonic (as suggested above), Nichicon, Rubycon, or United Chemicon and skip the drama of wondering why the device you fixed with those crap caps is broken again.
                        Re: Cap question
                        Black kapasitör 1000UF25V ok.
