Panasonic Inverter Refrigerator model NR-BY602XS - suddenly not cold overnight
    Re: Panasonic Inverter Refrigerator model NR-BY602XS - suddenly not cold overnight
    Originally posted by R_J View Post
    Refrigerators don't make cold, they remove heat, so the evaporator might not feel very cold. the gurgling sound does suggest the compressor is running. But the diagnostic still gives an error?
    I am actually quite uncertain about the Self Diagnostics instructions - seems to be a translation from Japanese to English, and some texts are quite unclear..
    Here's the summary of the Self Diagnostics done:
    1) Page7 - In process Inspection
    - after 1 minute: Illuminance Sensor LED is On, indicating BAD
    - after 30 minutes: All Freezer Control LEDs blinking - indicating BAD
    ** no description of what is BAD...
    2) Page 11 - SELF DIAGNOSING FUNCTION
    - based on the initial blinks (before they go off): PCD is BAD
    3) Page 15 - Not cool at all [ Both PC & FC (compressor does not operate) ]
    • Defect of control PCB.
    • Communication error between IC1 & IC201
    4) Page 16 - Cool, not enough [ Both PC & FC (compressor operates) ]
    • Defect of communication circuit and EEPROM circuit of control PCB.
    • Plug out and after 7 minute plug in again.
    Same outcomes in repeated tests. If these tests are done correctly, and the outcomes interpreted correctly - all seems to point to PCB Board faulty. Or possibly some setting is locked permanently like "compressor lock", or "defrost on", etc...
      Originally posted by beetle1303 View Post
      By data plate do you mean this in the pic below?
      I am just curious - if the compressor runs at whatever speed, and the inlet is slight cool, the outlet is warm (not hot), and the evaporator coil has refrigerant flowing with gurgling sound, etc, shouldn't the evaporator coil be slightly cool the the touch?
      Look at the end of the ( evaporator coil ) and see where very small tube is on one of coil and see if ice is forming there if so and only in one spot and does not grow then you have restriction or a gas leak
      Also remove the temperature sensor and warm it with your hand and see if the compressor will run at full speed
      9 PC LCD Monitor
      6 LCD Flat Screen TV
      1 Dell Mother Board
      15 Computer Power Supply
      All of these had CAPs POOF
        There is absolutely no frosting anywhere around the evaporator coil.. I don't think the refrigerant inside the coil is cool enough to form frost/ice. Touching the coil can feel the gurgling liquid flowing, but no sense of coldness at all.
        After power up for a few minutes, I place both defrost and freezer sensors in a cup of semi-hot water (around 50degC I guessed), but cannot really tell if the compressor is running at full speed or not.
        After 10-15 minutes, no observable difference in term of coldness in both compartments.
        How long does a normal fully working fridge takes to start feeling coldness if you place your hands in the freezer compartment?
          That what I thought ( “gurgling liquid flowing” ) I being to think that either the compressor ( will not run at full speed )[Controller issues] or [ compressor pumping issues ]
          OR
          You have a restriction in filter dryer ( OR ) cap-tube
          OR
          You have a gas leak
          This is where you would need a set service gauges and a specific type of amp probe to figure out what going on with this system
          9 PC LCD Monitor
          1 Dell Mother Board
            It should only take few minutes for the coil to start getting cold where the cap-tube is and the coil meet together
            When hear the liquid flowing like this is not a good sign and not getting cold
            There is not much refrigerant in theses units so if have a leak or a restriction it does not take it long for it not work
            9 PC LCD Monitor
            1 Dell Mother Board
              OK. Let me summarize the options to move forward:
              1) Refill refrigerant - this will determine if there is leakage. Maybe worthwhile
              2) Replace controller board - If a used fridge of same model can be found at low price.
              3) Replace some of the tubing - this will determine if there is blockage or restriction. Probably too costly for a old fridge..
              3) Replace compressor - not worth the money..
              Any feedback on these options? Or any other viable options?
                1) Refill refrigerant - this will determine if there is leakage. Maybe worthwhile (probably not)
                2) Replace controller board - If a used fridge of same model can be found at low price. ( good idea if you can find one )
                I commented on your though but for the most part you are right
                9 PC LCD Monitor
                1 Dell Mother Board
                  OK... Looks like it's praying for a kind donor, or paying for a reasonable price used unit as tuition fee.
                  I have started browsing and found a few identical model, but price a little stiff after costing in transportation.
                  I guess will need a little more time to catch one...
