Fix Brother MfC-J430W Paper Jam
    I still get the message "Misfeed" even though I removed the jammed paper.
    To clear the paper jam error after removing the jammed paper, open and close the scanner cover.
    If the error message persists, a piece of paper in the printer might be the cause.
    Follow the steps below to remove any scraps of paper from inside your device.
    if I try to turn off the handle, it does not work either
    Error Medung "Try Later !!!"
    NOTE: The illustrations are representative, so they may differ from your device.
    Can someone help me?
    Thank you very much
    Re: Fix Brother MfC-J430W Paper Jam
    While I haven't worked on to many inkjet-type printers, I have repaired a large volume of a few different models laser printers, one of these being a Brother model.
    These had paper sensors that a small scrap of paper could 'fall' into and trip. Or if paper was to 'forcefully' removed, it could jam or break the sensor mechanism.
    I'd recommend closely examining the path the paper travels through the printer.
      OK thank you
      I will try it again
        Agree. I have two Brother printers - and the wife always manages to jam them. Hidden from view is always a small piece of paper somewhere in the paper path. Keep looking.
