Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Game Consoles & Other Weird Devices
Old 01-30-2023, 02:50 PM   #1
survivalbloke
survivalbloke's Avatar
City & State: Maryland
My Country: United States
Line Voltage: 120VAC 60Hz
Default Xbox One S - need PSU schematic and boardview
I've got an Xbox One S PSU opened up. I'm not getting 12vdc output as I do with my test unit. I'm sure this board must have a fuse but I don't see it as everything on the board is poorly labeled.
survivalbloke is offline   Reply With Quote
Old 01-30-2023, 03:14 PM   #2
stj
stj's Avatar
City & State: Europe
Default Re: Xbox One S - need PSU schematic and boardview
post a picture - i dont think there is only one type
as for a fuse, look for a small box like a polyester capacitor but brown
Old 01-30-2023, 04:16 PM   #3
survivalbloke
imgur
Thanks! What's the rectangular component which is in the lower right area on the last pic? It has two connections, is black in the middle and greenish around its edges?
Thanks!
Old 01-30-2023, 05:08 PM   #4
stj
stj's Avatar
stupid site makes the pictures SMALLER when i click on them!
the green part is a resistor,
the fuse is gray and in the corner where the connector is soldered.
you can see one of the wires connects directly to one end
Old 01-30-2023, 05:16 PM   #5
survivalbloke
Gosh, what an AWFUL picture. I'm confused and will take another, clear pic, under my scope so you can point out the fuse. I do see something in that corner, but it doesn't look soldered directly. It looks like it could possible be soldered to the same trace.
Old 01-30-2023, 05:25 PM   #6
diif
City & State: Midlands
My Country: England
Click Go Advanced below and then the paperclip to add them here.
diif is offline   Reply With Quote
Old 01-30-2023, 06:48 PM   #7
stj
stj's Avatar
you dont need a microscope, just follow the tracks from the socket wires
Old 01-30-2023, 07:19 PM   #8
lotas
City & State: Sochi
My Country: Russia
In order not to search for a long time, I will make the task easier.
lotas is online now   Reply With Quote
Old 01-31-2023, 08:10 AM   #9
survivalbloke
I was just about to post another pic - but of the opposite side. OK, so that's a fuse for the AC side, I wasn't thinking like that. My mind is always in motherboard diagnostic mode. and this is the first time I've ever dabbled with PSU's. Now I get it - thanks!
**30sec later** Welp, fuse is good. I'm out of ideas lmao.
Old 01-31-2023, 08:13 AM   #10
survivalbloke
If anyone knows common faults of this unit, I'm all ears. The fuse is good. I'm about a 5-6 on motherboard diagnostics but know nothing about PSU diagnostics. I've found a lot of info online about the Xbox One, but can't seem to find any info on the One S.
Old 01-31-2023, 11:07 AM   #11
stj
stj's Avatar
if the fuse is good there are 2 common psu problems - not specific to this one.
first - shorted output diode.
so meter between the 12v and ground contacts
second - but i dont thing its old enough, although it is in a sealed box, the small startup capacitor that gets the chip running.
it's going to be an electrolytic connected to the chip with a value between 10uf and 47uf usually.
if it fails the psu cant start
Old 01-31-2023, 11:29 AM   #12
survivalbloke
You're awesome! the 12V rail is shorted to ground. Using voltage injection I can see two components heating up. In this picture, that resistor is the first to boil off but right after, that component marked K401 boils off, so I'm imagining it's the K401? What type of component is that?
Old 01-31-2023, 11:38 AM   #13
R_J
City & State: ☻
My Country: Canada
K401 seems to be a TS321IL
R_J is offline   Reply With Quote
Old 01-31-2023, 11:42 AM   #14
survivalbloke
Thank you. Did you just google 'K401'? If so, I'm going to feel dumb. So that's an operational amplifier. I removed it from the board and the short is gone. I'll get that ordered up. Thanks to all of you!
Old 01-31-2023, 12:50 PM   #15
stj
stj's Avatar
is that ceramic cap top-right even soldered down properly?
Old 01-31-2023, 01:07 PM   #16
survivalbloke
Yes, just a bad camera angle.
Badcaps.net Technical Forums © 2003 - 2023
Copyright ©2000 - 2023, Jelsoft Enterprises Ltd.
