Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Game Consoles & Other Weird Devices
Old 12-08-2022, 04:24 PM   #1
fab13
City & State: Arras
My Country: France
Question ps4 power supply resistance out of order, what to choose?
Hello
After checking this resistor which gives no value on the ohmmeter on a PS4 SLIM power supply.
I would like to change it but by which power I can choose it knowing that this resistor is on the primary part that is to say on the 230/400 V side
Value 16.8 Ohm normally according to color code (See photo)
1st ring = Brown = 1
2nd ring Blue = 6
3rd ring Grey = 8
4th ring OR Multiplier = x0.1 Ohm
5th ring Red = +/- 2 %.
Tolerance of either + or - 0.336 ohms
Dimension of the resistor Length = 6.4mm, Width 4.8mm
Can I place one between 15 and 17 Ohm or a little more?
What power in Watt I can order if it is 2W or 3W
I don't want to do anything stupid about the value to choose
Thanks a lot to you
fab13 is offline   Reply With Quote
Old 12-08-2022, 05:18 PM   #2
lotas
City & State: Sochi
My Country: Russia
Default Re: ps4 power supply resistance out of order, what to choose?
This is a safety resistor, plays the role of a fuse (0.16 Om. 5%).
lotas is online now   Reply With Quote
Old 12-09-2022, 01:21 PM   #3
fab13
City & State: Arras
My Country: France
Strange because it doesn't even sound continuous in this case
Old 12-09-2022, 02:33 PM   #4
lotas
City & State: Sochi
My Country: Russia
What is strange here, 3 stripes (silver) is a multiplier of x0.01.
Old 12-12-2022, 01:06 PM   #5
fab13
City & State: Arras
My Country: France
Question Re: ps4 power supply resistance out of order, what to choose?
I was really surprised to see this silver stripe in the 3rd position, so I considered it as a grey color.
I can't find any other information about a silver band in the 3rd place for 5 rings.Maybe it should not be taken into account then =S so I will have to calculate it as 4 rings.
This would give 0.16 Ohm but tested in several modes Diode or megaohm the resistance gives nothing at all.
Only I need an example of a resistor on the same power supply of a ps4 slim
Old 12-12-2022, 01:49 PM   #6
R_J
City & State: ☻
My Country: Canada
Is this the resistor at location F3? if it is, it is a 0.16Ω-2watt. Lotas post #2 is correct
R_J is offline   Reply With Quote
Old 01-17-2023, 03:53 PM   #7
fab13
City & State: Arras
My Country: France
So the resistor is indeed 0.16 OHM which acts as a fuse we will say.
I ordered a 2W and it is much smaller, so I took a 3W which is the same size and the power supply works now
Many thanks to you
Old 01-17-2023, 09:21 PM   #8
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist Tech
I don't think I've ever seen a multiplier band of gray (and definitely not white), it's always been silver of that set of similar colors.
Purple multiplier is rare enough as it is... I think I've only seen 1 or 2 ever.
eccerr0r is offline   Reply With Quote
Badcaps.net Technical Forums © 2003 - 2023
Copyright ©2000 - 2023, Jelsoft Enterprises Ltd.
