Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Game Consoles & Other Weird Devices
Old 11-30-2022, 10:20 AM   #1
Crashpro2003
City & State: Jacksonville North Carolina
My Country: United States
Default Robosapein V2 Bot PCB repair wanted
Anyone know of a good circuit board repair company that can fix a board without a schematic or board view?
Last edited by SMDFlea; 11-30-2022 at 06:04 PM.. Reason: Added "Robosapein V2 Bot" to thread title
Crashpro2003 is offline   Reply With Quote
Old 11-30-2022, 10:25 AM   #2
stj
stj's Avatar
City & State: Europe
Default Re: PCB repair wanted
thats vague, what is it?
got any pictures?
fault description?
most things are repaired without a schematic.
Old 11-30-2022, 12:40 PM   #3
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist Tech
Have to assume it's the robot. but if it's visibly damaged it usually can be done without schematic. If it's not visibly damaged and there's no obvious signs (shorts, etc.) then it gets mighty hard without a schematic and repair costs increases rapidly due to debug time...of which a reverse engineered schematic may be needed/generated, which may end up above the cost of a new unit...
eccerr0r is offline   Reply With Quote
Old 11-30-2022, 05:57 PM   #4
Crashpro2003
It's a circuit board out of a discontinued vintage Robosapein V2 Bot I'm Trying to repair. Board seems to be dead due to cheap wire insulation. It flakes and falls off, then shorts something out in all units. Bot is not working after being rewired. And I can not find the schematic or board views for it anywhere online. There appears to be a burn mark on the board which is circled in the attached photo. Although it could also be a blue company test check mark covered in flux, placed after manufacturer tested it. Not sure. Looking for someone to check over the board and fix it if needed.
got any pictures?
fault description?
Old 11-30-2022, 06:37 PM   #5
stj
stj's Avatar
Default Re: Robosapein V2 Bot PCB repair wanted
the mark is marker pen under the glue.
the glue is the cause/problem, it becomes conductive when it gets old.
this is a well known curse in psu's and audio gear.
you need to get the glue off by lifting it with a small flat screwdriver or similar
Old 11-30-2022, 08:52 PM   #6
Crashpro2003
Wow No shit? There is a lot it on the board. I know this sounds like dumb question. But does that mean that every component that it is in contact with is potentially shorted out? I thought it was just dried liquid flux. Thanks for the information.
Old 11-30-2022, 09:22 PM   #7
stj
stj's Avatar
it's not going to be dead-short,
but it will have a resistance that drops as it darkens and ages - when it's really bad the glue turns almost black and very hard.
it can also be corrosive to the component legs
Old 12-01-2022, 10:13 AM   #8
Crashpro2003
Thumbs up Re: Robosapein V2 Bot PCB repair wanted
The glue on the board has the characteristics of rubber or contact cement. It stretches a lot before it begins to peel off. Don't want to scratch at it too hard so as to not damage any traces on it. I have found out that Mineral Spirits will help remove rubber cement. Will using it, sparingly, damage the coatings or other parts on the board?
BTW You have been the greatest help to me so far.
Old 12-01-2022, 10:27 AM   #9
stj
stj's Avatar
i dont think meth-spirit will damage anything, but i know acetone will.
test the spirit to see if it damages the connectors though.
Old 12-02-2022, 12:55 PM   #10
Crashpro2003
Hi
I dabbed on Isopropyl alcohol (didn't soak board in it) to soften the glue and carefully picked all of it off. Bot still not working. Attention now is on the Main board marked with EW and numbered (6028-1G). Good call BTW. The mark on the board was made with a marker, not a burn mark. Shouldn't there be a copy of the schematic and board views for these boards out there somewhere?
Thanks again for all your help
Old 12-02-2022, 02:45 PM   #11
stj
stj's Avatar
boardview is just a mac thing,
schematics are down to the maker to share or not.
that board you cleaned doesnt really need one,
it's clearly just a repeating pattern of transister switch circuits presumably to let the logic signals drive the motors.
if it failed it would only effect one motor
Old 12-02-2022, 04:39 PM   #12
diif
City & State: Midlands
My Country: England
Boardviews are most commonly known for Apple devices but it's not an exclusive thing, I have some from Dell. HP, IBM, Toshiba and some for graphics cards.
diif is offline   Reply With Quote
Old 12-02-2022, 05:34 PM   #13
petehall347
City & State: worcester
My Country: United Kingdom
probe the glue with your dmm and see if it really is conductive ..this is how i found it myself before i found it myself and reported it on the internet . sansui were bad for it .
Old 12-04-2022, 11:17 AM   #14
Crashpro2003
Think I may have found the issue of "no power." White smoke or heat mark on back of Main Board. Behind what might be a fuse or thermal cut off or coil for chip but unsure. It's labeled DY 4.000 See attachments. Tested across poles and it is open, no continuity. Also don't know what DY stands for or where to get a replacement. Any help will be appreciated again. Can you private message me with your thoughts on this? Being a Newb I have a tough time navigating this forum. Thanks again
Old 12-04-2022, 11:46 AM   #15
CapLeaker
Leaking Member
CapLeaker's Avatar
City & State: Atlantic Canada
My Country: Canada
Line Voltage: Ground, 0Hz
That is a 4 MHz crystal. That could be a failure point, but I think the problem is elsewhere, because you need to get power first.
Old 12-09-2022, 02:03 PM   #16
Per Hansson
Per Hansson's Avatar
City & State: ----
My Country: Sweden
Line Voltage: 230v 50Hz
Check the area marked in a blue rectangle, is that trace broken or is it just an optical illusion?
Old 12-09-2022, 02:16 PM   #17
stj
stj's Avatar
nice find.
it actually looks both burned AND on a through-hole to me.
Old 12-09-2022, 02:42 PM   #18
lotas
City & State: Sochi
My Country: Russia
No, these are the remains of rosin when this module was soldered manually.
lotas is online now   Reply With Quote
Old 12-09-2022, 07:22 PM   #19
sam_sam_sam
City & State: Some times Sunny Jacksonville FL
Line Voltage: 120 Volts 60 HZ
Look closely at all the soldering joints for ghosting rings around the the bottom of the joints or a lot of flux or corrosion on the soldering joints or cracked soldering joints ( I see some soldering joints that look very ? able
I would look at under a magnifying glass for what I have above )
After that then start looking up part numbers and see what they are and checking them for functionality
Both of them are very time consuming projects
I once fixed a battery operated magnet plate for steal plate crane lifting device that the hole board had corrected soldering joints I had resolder the entire board and did manage to get the device to work correctly again but it took several days to do this
The small red board on the main part of circuit board looks like it is some type of micro controller which could be damaged by the shorting of wires hopefully not
Please post a picture of power supply board as well because the issue might be on this board as well
9 PC LCD Monitor
6 LCD Flat Screen TV
1 Dell Mother Board
15 Computer Power Supply
All of these had CAPs POOF
sam_sam_sam is offline   Reply With Quote
Old 12-11-2022, 03:08 AM   #20
Per Hansson
City & State: ----
My Country: Sweden
You need to look in the blue rectangle I put, not the red circle drawn by Crashpro2003.
Badcaps.net Technical Forums © 2003 - 2023
Copyright ©2000 - 2023, Jelsoft Enterprises Ltd.
