Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Game Consoles & Other Weird Devices
Old 03-24-2022, 04:21 PM   #1
Themi
City & State: London
My Country: Scotland
Default PS5 brief power won't start
powers on + beeps briefly for a second displaying a blue light then powers back off
  • checked all fuses ok
  • checked for voltages, found 12v, 5v, 3.3v, 1.8v (I am not 100% sure where to successfully check for all)
  • started checking each inductor ohms to ground, all ok apart from a 1R5 near the DCIN, shorted 0.3ohms
  • checking components around the inductor appears a small plane on the front of the board is shorted progressing through to a plane on the rear side
  • surrounding circuits not on this plane are not affected
  • I have check caps around the board in each various circuit for a similar short and have found none (so far)
  • everything appears localised to this single area
  • I did remove the mosfet on the right (stupidly) as I had a lapse of judgement and forgot the inductor to the right was still in circuit. I tested it off board anyway and it's fine
red shorted (0.3ohms) , blue not shorted
shorted inductor
top of the board
back of the board
mosfet? end of the back of the board shorted trace (I can't find a datasheet)
I don't have voltage injection + thermal yet but I'm in the process of buying both.
I am wondering where to progress through to next. The short seems so localised to this single area that I am tempted to start removing the ceramic caps but wondering if anyone has any further input.
File Type: png 045-C451-B-ABB3-46-E3-B53-F-5058-C29-BA7-D9.png (1.06 MB, 203 views)
Last edited by SMDFlea; 05-02-2022 at 03:11 PM.. Reason: images copied to badcaps from external image host
Themi is offline   Reply With Quote
Old 03-25-2022, 03:56 AM   #2
Themi
Default Re: PS5 brief power won't start
found out it was one of the small caps below one of the mosfets which had gone bad, replaced it for another and it's back up an running
Old 05-02-2022, 01:29 PM   #3
kjchatman
City & State: spring lake/ north carolina
My Country: united states
my ps5 power supply is only supplying 6 volts. can i use my bench power supply to troubleshoot the board?
kjchatman is offline   Reply With Quote
Old 05-03-2022, 03:52 AM   #4
stj
stj's Avatar
City & State: Europe
if the psu is only supplying 6volts - shouldnt you fix it first?
Old 08-13-2022, 03:51 PM   #5
kjchatman
my ps5 has a display for a split second then it beeps 3 time and cuts off
Old 12-12-2022, 09:24 AM   #6
HelpMeRepair
City & State: Montreal
My Country: Canada
Line Voltage: 120VAC 60Hz
Hi Themi do you remember where was that BAD CAP exactly ? =) thanks
HelpMeRepair is offline   Reply With Quote
Old 12-14-2022, 04:17 AM   #7
Aliseo
Aliseo's Avatar
City & State: Modena
My Country: Italy
Line Voltage: 230VAC 60Hz
do you try to inject voltage?
Aliseo is offline   Reply With Quote
Old 02-18-2023, 04:41 PM   #8
Themi
sorry I've only just seen this.
you still need the info?
Old 02-18-2023, 09:38 PM   #9
keklikelektronik
City & State: sofia
My Country: bulgaria
first you try remove the coil.which side is short.next remove the smd caps first.and mosfet.i think its a shorted mosfet.
keklikelektronik is offline   Reply With Quote
Old 03-13-2023, 04:56 AM   #10
Son23
City & State: Frankfurt
My Country: Germany
My ps5 dropped and has same issue 1 second blod.
Back and around the APU the capacitor are shorted. Is this normal?
I don't see any video where these capacitors are measured.
apart from that everything is alright and can’t find any other problems.
I would appreciate any help!
Son23 is offline   Reply With Quote
Old 03-13-2023, 05:03 AM   #11
CapLeaker
Leaking Member
CapLeaker's Avatar
City & State: Atlantic Canada
My Country: Canada
Line Voltage: Ground, 0Hz
I'm a: Hobbyist Tech
Is it just low on resistance or is it a dead short?
Old 03-13-2023, 10:57 AM   #12
Son23
My Country: Germany
Dead short
Old 03-13-2023, 01:43 PM   #13
lotas
City & State: Sochi
My Country: Russia
Originally Posted by Son23 View Post
Dead short
What is shown in the photo is the choke (inductors), they will show a short circuit.
If it fell, then the chip most likely fell off (the processor under the radiator), only a reball will help, if the nickels on the motherboard under the processor have not come off.
lotas is online now   Reply With Quote
Old 03-15-2023, 10:35 PM   #14
vinse
City & State: besancon
My Country: france
yes and should be 12v
vinse is offline   Reply With Quote
Old 03-15-2023, 10:36 PM   #15
vinse
My Country: france
Dead short
not sur dead short on those beware tey have low resistance
Badcaps.net Technical Forums © 2003 - 2023
Copyright ©2000 - 2023, Jelsoft Enterprises Ltd.
