Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > General Electronics Technical Discussion
Thread Tools Display Modes
Old 08-20-2020, 11:30 AM   #1
pintglass
City & State: Congleton
My Country: United Kingdom
I'm a: Knowledge Seeker
Default Back to Back Transformers
Im currently building an isolation transformer from 2 240v-12v transformers, wired with the 2 12V secondaries joined to give 240V out, which I am getting.
The Issue I have is that I'm getting 100Hz out from 50Hz in.
Can anyone tell me why that may be?
pintglass is offline   Reply With Quote
Old 08-20-2020, 12:10 PM   #2
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
My Country: USA
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist Tech
Default Re: Back to Back Transformers
Either you're measuring it wrong or the source transformer has a rectifier output... ?
eccerr0r is offline   Reply With Quote
Old 08-20-2020, 02:21 PM   #3
pintglass
Both the transformers are from old 12V battery chargers both of which had rectifiers in them aswell.
If the transfomers had rectifacation would they still need a seperate rectifier.
I'm just measuring with my multimeter and going off what its reading which is 100Hz
Old 08-20-2020, 02:48 PM   #4
petehall347
City & State: worcester
closest i could find without using diodes is this .but your set up isnt like it ... maybe try moving the transformers further away from each other ...
petehall347 is offline   Reply With Quote
Old 08-20-2020, 04:00 PM   #5
budm
budm's Avatar
City & State: S.F. Bay area
My Country: USA
Line Voltage: 120V 60Hz
Show us how you have them all connected up.
You need to connect the 12V winding directly together, no diode, nothing but just the 12VAC winding of each transformer.
240VAC into first transformer 240VAC winding, 12VAC winding of first transformer to 12VAC winding of second transformer, 240VAC winding of second transformer for 240VAC Isolated output.
__________________
budm is offline   Reply With Quote
Old 08-20-2020, 04:40 PM   #6
pintglass
Thats how I've got them setup.
I've attached an image of how there wired. The transformer in the bottom of the image is the 240V in, with a fuse before it, then the two 12V's are connected together then the output is the transfomer at the top.This goes into a power meter display then into a DPST switch.
Old 08-20-2020, 05:01 PM   #7
budm
budm's Avatar
My Country: USA
So direct connection without any diodes anywhere, you are seeing 240VAC 100Hz at the output?
Old 08-20-2020, 05:17 PM   #8
stj
stj's Avatar
City & State: Europe
My Country: some shithole run by Israeli agents
I'm a: Professional Tech
you may be getting transfer between the transformers because they are oriented in line with each other.
magnetic flux through the air or even the metal baseplate.
do you have a scope?
stj is offline   Reply With Quote
Old 08-20-2020, 06:14 PM   #9
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
My Country: USA
The coupling is a nice theory but doesn't really hold water, you need a phase shift of some sort to get doubling and coupling is in phase or at least very close to be in phase. Still doesn't explain...
What about the frequency of the 12V between the two? What about after the measurement jig before the first transformer?
I have to say that there's some measurement issue or some other noise source like the measurement jig... Scope would indeed be nice.
Old 08-20-2020, 06:47 PM   #10
redwire
City & State: Alberta
My Country: Canada
PZEM-021 energy/power meter uses a capacitive-dropper for power and likely causing some ringing on the AC waveform output of the second transformer when it has no load on it. Are you sure you've got the right winding, I see some steel lamination cut off and extra windings on it and 247V label?
Connect a light bulb load on the output and I'd guess the frequency reading would mysteriously half.
redwire is offline   Reply With Quote
Old 08-21-2020, 12:03 AM   #11
pintglass
Yes with direct connection and no diodes my multimeter is showing 100Hz
Yes I have a scope
I only get 50Hz on the 12V windings
Even if I disconnect the energy/power meter I still get 100Hz on the output Transformer.
The output transfomer does have more than one tap but I still get 100Hz on both of them.
Old 08-21-2020, 03:52 AM   #12
sam_sam_sam
City & State: Some times Sunny Jacksonville FL
My Country: USA
Line Voltage: 120 Volts 60 HZ
You do have the right phasing or you will not get the right voltage or current
On the primary and secondary winding
I done this before and you have to get it right for it to work correctly
__________________
9 PC LCD Monitor
6 LCD Flat Screen TV
1 Dell Mother Board
15 Computer Power Supply
All of these had CAPs POOF
sam_sam_sam is offline   Reply With Quote
Old 08-21-2020, 04:03 AM   #13
pintglass
What do you mean by having the right phasing ?
Old 08-21-2020, 04:31 AM   #14
sam_sam_sam
My Country: USA
Have you noticed that on some transformers have a dot on them on one corner one side then on the side of the transformer there is another dot on the opposite corner
This is the phasing of the transformer when you hook up two in series you hook it one way when you hook it up in parallel you hook up another way
This also depends on the transformer you are using
Most transformers are not marked by the way
If you google how to determine the phasing you should be able to figure it out
Old 08-21-2020, 07:07 AM   #15
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
My Country: USA
Again this does not make sense. Phasing at most will invert or not invert the sinusoid of the AC current, but the downstream equipment should not care what phase it's running at. You can try swapping the connection of the 12V/low voltage wires to put things in phase.
This must be some noise problem that your meter is picking up though I'd say the 100Hz is a second harmonic that the meter is picking up. The only thing that sticks out at the moment is that your secondary transformer is using two windings hooked up in parallel or this should be the case. A mismatch may cause some weird behavior. What if you use the two transformers the other way around -- use the low impedance of line power to override the parallel winding mismatches?
Old 08-21-2020, 09:04 AM   #16
pintglass
Do you mean that the output transformer's 240V side has dual windings in parallel, as I am only connected to one of them.
Old 08-21-2020, 10:10 AM   #17
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
My Country: USA
yeah you have a mess there, can't exactly tell how you're connected. Might be some noise being introduced there too, dunno...
Old 08-21-2020, 04:27 PM   #18
sam_sam_sam
My Country: USA
No what I am talking about is if you have it out of phase then you will not get any voltage or current or you are shorting both transformers out
Old 08-21-2020, 05:07 PM   #19
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
My Country: USA
The windings are all in parallel and the signal (AC line) is symmetric/sinusoidal, so you don't have to worry about it.
If one was planning to make a voltage doubler out of these transformers, they'd need to be in series, and this would make a difference.
However 0 or 180 phase difference, the peaks and valleys would all appear at the same time, cancelling each other out. Need a phase shift to double the frequency somehow...
Old 08-21-2020, 05:48 PM   #20
redwire
My Country: Canada
This schematic diagram might help. If OP can verify.
Phasing is important for the dual-primary tranny but more so if they were autotransformer connected which is what sam is talking about.
Adding a small load will get rid of the frequency doubling OP is seeing.
I want an earth ground connection and don't see it.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2022
Powered by vBulletin ®
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
