Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Power Supplies and Power Supply Design
Thread Tools Display Modes
Old 05-14-2022, 04:30 PM   #21
lotas
City & State: Sochi
My Country: russia
I'm a: Knowledge Seeker
Default Re: Cyberpower CP900EPFCLCD - F03 Error
You should have a high DC voltage on C3 - 400 V 10 uF, if it is not there, then the AC voltage does not reach the diode bridge, you need to check the fuse or low-resistance resistor, or the relay between the AC 220v input and the diode bridge did not work.
lotas is offline   Reply With Quote
Old 05-14-2022, 04:48 PM   #22
Per Hansson
Per Hansson's Avatar
City & State: ----
My Country: Sweden
Line Voltage: 230v 50Hz
Yes, could also be that the bridge rectifier BD1 is broken, so check if you have input AC voltage on it.
__________________
Per Hansson is offline   Reply With Quote
Old 05-14-2022, 05:11 PM   #23
lotas
City & State: Sochi
My Country: russia
And some more UPSs will not start (they will not turn on the relay to start the switching power supply) without a battery, you need to check the power with the battery.
Old 05-14-2022, 06:10 PM   #24
Shinjinkun
City & State: Altea
My Country: Spain
Quote:
Alright, I checked the values for the BD1 component:
input AC: 0.310V
output DC: 0.403V
I also checked the cable that comes from the input AC cable (after the fuse) to see if the current was getting into the board. It has 233V, so it seems that at least until that point the current is as expected.
Using the attached picture Cyberpower04.jpg, where should I measure and which values should I expect? If you could pin-point in the picture, it will be even better, as I am a total beginner.
By the way, I always connect the battery for the tests
Shinjinkun is offline   Reply With Quote
Old 05-14-2022, 06:26 PM   #25
lotas
City & State: Sochi
My Country: russia
Check this fuse.
Old 05-14-2022, 06:58 PM   #26
Shinjinkun
City & State: Altea
My Country: Spain
Check this fuse.
Done! I checked with the multimeter in continuity, and is showing OL, and it is not beeping. That means it doesn't have continuity, right?
Old 05-14-2022, 07:07 PM   #27
lotas
City & State: Sochi
My Country: russia
So he burned out and broke the chain.
Old 05-15-2022, 12:42 AM   #28
Per Hansson
City & State: ----
My Country: Sweden
Quote:
Great, I would replace this fuse with an old incandescent 40w or 60w light bulb.
If this bulb turns on bright when you turn the UPS on you still have a big problem somewhere.
You can of course skip this test and just replace the fuse but you risk blowing everything up again...
Old 05-15-2022, 06:43 AM   #29
Shinjinkun
City & State: Altea
My Country: Spain
Ohh, I heard about the light bulb thing before, but I am not sure how to do it.
So, if I understand correctly, I will need a lamp holder (or bulb socket, not sure the correct name) with two cables. Where should I connect these two cables? To the same positions the broken fuse are connected? Or somewhere else?
Regarding the replacement fuse, I understand that it must be a 250V 2A one, fuse with leads through holes, but I have seen different kinds of fuses and I am not sure which one to pick. Would you mind sharing a link to buy them here in Europe, let's say Amazon, Aliexpress or Ebay? Or at least telling me the keywords I should look for?
Finally, it is probably that other components in the chain are also affected before arriving the Viper22a. Is it possible to test these components individually without having to connect the whole system? Or at least, a way to isolate parts of the circuit to avoid blowing anything else?
Thanks again for all your help.
Old 05-15-2022, 12:35 PM   #30
Per Hansson
City & State: ----
My Country: Sweden
Yes exactly, just connect it where the fuse was before.
Cut away the heatshrink tubing from the old fuse and read what it says on the ends: there are fast and slow fuses and it is important to pick the right type...
Yes some parts can be tested, like diode check the bridge rectifier for example.
I would also check the 550ohm resistor and optocoupler U3, this can be done with diode check too.
As for the rest as long as you use the lamp as a current limiter there is not that much that can go wrong...
Old 05-15-2022, 05:17 PM   #31
Shinjinkun
City & State: Altea
My Country: Spain
Perfect. I will get a lamp holder tomorrow. I remember I have one in the garage.
Alrighty. I hope the fuse has some print on it. Otherwise, is going to be difficult to pick the fuse.
The bridge rectifier is the BD1 component (BD107G), right? I measured it, without removing from motherboard, with the negative in the AC inputs, and was getting 0.595V in diode mode. The same putting the negative in the positive DC, so I am not sure if this means it works.
However, the U3 component doesn't give me any readings. I didn't remove it from the board either.
Old 05-16-2022, 12:32 PM   #32
Shinjinkun
City & State: Altea
My Country: Spain
I removed the fuse from the board, but it doesn't clarify much. Attached some pictures for you to see.
The markings on the fuse are like this:
RSFR-H on the self-shrinking tube.
2A 250V | in one side
TAP c UL US | on the other side
I have been looking for hours to see if I can find the same kind of fuse, but no luck so far. Do you have any idea about which one should work?
Old 05-16-2022, 12:47 PM   #33
lotas
City & State: Sochi
My Country: russia
Yes, put any size on 2A.
https://aliexpress.ru/item/400006248...00000159518588
Old 05-16-2022, 01:44 PM   #34
Per Hansson
City & State: ----
My Country: Sweden
The "T" in "TAPc" could stand for "Time Delay" i.e. a slow blow fuse.
But none of those letters really make sense so could just be production numbers...
If you try with a quick blow fuse you don't risk anything.
I.e. you can always switch to a slow blow instead if it blows.
But of course start with the incandescent lamp: that is the most important safety test really...
Correct, you can also search Youtube or Google for some bridge rectifier test videos, in total there are 4 diodes to test...
As for the optocoupler if you can't read anything it is probably broken.
So desolder it and the 550ohm resistor from the board and test again.
Old 05-16-2022, 04:32 PM   #35
Shinjinkun
City & State: Altea
My Country: Spain
Yes, I will use the incandescent lamp first, as it will take several days or weeks to get the fuse replacement. Problems of living in a small village. I will order the replacement as soon as possible.
I watched two or three of these videos, and it looks like the BD1 rectifier is in order.
Actually, I tested U3 again, and I get 1.082V between anode to cathode. It seems that a small circuit and a battery are needed to fully test the optocoupler, so I may have to trust it for the moment.
In the end, I will desold the resistor and put a replacement.
I will let you know once I get the lamp holder solded.
Old 05-19-2022, 03:28 PM   #36
Shinjinkun
City & State: Altea
My Country: Spain
Hi guys!
I replaced all the components again just to be sure. When I removed the 550Ω, I checked it and it was in short, so I replaced it.
Regarding the lamp holder, I attached the contacts to the fuse, as it is open anyway. Attached the pictures for some reference.
So now, should I connect everything again and test all the components? Which steps should I follow?
Old 05-20-2022, 01:10 PM   #37
Per Hansson
City & State: ----
My Country: Sweden
Yes, just plug it in now, the lamp is allowed to flash once bright as the caps charge.
After that it should be quite dim.
If it is bright then it is expected something is still shorted.
Old 05-24-2022, 01:04 PM   #38
Shinjinkun
City & State: Altea
My Country: Spain
Sorry it took me some time to make the proper tests.
Well, I finally connected the lamp and, as expected, is continuously bright. At least, this way, is not burning the components again.
As I wasn't sure about what to do, I took several measures of voltage in different points. Please check the attached pictures.
I would like to point out a few things:
First, I found only 0.7V in the ceramic capacitor C6 (AC472M), while in C5 that is exactly the same type, found 232V.
Then, the film capacitor C22 measures only 5.37V. Shouldn't it be also 230V?
In the end of this branch, the AC/DC converter inputs 3.96V AC and outputs 2.019V DC.
Going the other way, I am not sure how to test the voltages for the relay K1.
But I found that C7, the 1.0uF X1 CTX film capacitor measures as a short. Could it be that this component is broken, even that when I measure it disconnect I don't get the short?
Please keep helping me to try to fix this!
Thanks a lot
Old 05-25-2022, 06:40 AM   #39
Per Hansson
City & State: ----
My Country: Sweden
Ok, so with these values it looks to me like your incoming line voltage is 233VAC
Since you measured 227v in series with the bulb this is the voltage it drops.
So therefore your measurements of 5VAC show the remaining AC (not being dropped) i.e. it points to the short.
In this case you are reading a very low voltage on the bridge rectifier of only 3.96VAC and 5.361VAC in C22 before it.
This points to the bridge rectifier or something after it being shorted.
I would remove the bridge rectifier from the board and test both again:
This will help narrow down where the issue lies.
As for the voltage difference in C5 and C6 that is because one is connected from phase to neutral (230vac side).
And the other between neutral and ground side (this should in a perfect world read as 0vac but a low voltage like you see here is normal).
As for K1 and the capacitor C7 I don't see how they are connected but I would ignore them for now, the goal is to get power to the Viper chip first.
In any case I'm 99% sure that the voltage generated by the Viper is used to control the relay so there is no point going down that path (yet)
Old 05-29-2022, 11:10 AM   #40
Shinjinkun
City & State: Altea
My Country: Spain
Well, that must be the current issue, indeed.
I removed the bridge rectifier and, when I connected everything to mains, the light bulb was off. Then measured the voltage. This time, I was getting 230.8V into both inputs for the DB107 bridge rectifier. I suppose that means that everything before it should be working fine, right?
Ahh, understood. I didn't know that was the correct value I should get.
Alright, let's check the right part later on.
It took me some time to respond cause I was about to receive a package with the fuse replacements and some extra DB107. I replaced the DB107 with a new one, and when I connected everything again, the light bulb was on, and the values back like last time.
I disconnected it and thought an idea. I removed the viper22a from the socket, and got a few more measures. First, the bulb was off (probably because part of the circuit was not accessible). The DC output from the rectifier had 316.2V DC. The C3 capacitor measured 316.2V, and C14 between 40 to 50V, but couldn't write it down cause while using the probes, I must have shorted something, and fried the 550ohm resistor and C14 probably. Probably it wasn't a very good idea removing the viper, but at least isolates a bit where the short is.
Then, from now on, what do you recommend me to do? Should I replace the blown components and try again, or remove some of them to try to find the faulty section?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2022
Powered by vBulletin ®
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
