Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting TVs and Video Sources
Thread Tools Display Modes
Old 03-08-2022, 10:04 AM   #1
Storyteller12
City & State: Virginia
My Country: USA
I'm a: Knowledge Seeker
Default Vizio E65-F0 Backlight On, No Picture
Have this TV with no picture. When I first got it the same symptom. Backlight on but no picture. I check the tcon fuse and it was bad. So I ordered new tcon and mainboard packaged together.
I replaced the tcon and mainboard and still have the same symptom but the fuse on the tcon did not blow.
I tried unplugging one side at a time of the lvds cables and still get no picture. Not even half white screen. Just black screen with backlights on.
Anyone have any suggestions or run into this problem on this model?
Storyteller12 is offline   Reply With Quote
Old 03-08-2022, 10:06 AM   #2
Storyteller12
My Country: USA
Default Re: Vizio E65-F0 Backlight On, No Picture
Power supply
Old 03-08-2022, 10:07 AM   #3
Storyteller12
My Country: USA
Main board
Old 03-08-2022, 10:08 AM   #4
Storyteller12
My Country: USA
Tcon
Old 03-08-2022, 10:10 AM   #5
Storyteller12
My Country: USA
Also I found this eeprom chip on the panel buffer board. Never seen this before. Maybe it’s bad/ corrupt?
Old 03-08-2022, 10:21 AM   #6
dskall
dskall's Avatar
City & State: Bakersfield ca.
My Country: usa
Line Voltage: 120VAC 60Hz
I would be checking t-con voltages. Maybe panel dragging down a voltage.
__________________
dskall is offline   Reply With Quote
Old 03-08-2022, 11:47 AM   #7
Storyteller12
My Country: USA
Did some more digging around and found a few shorted caps I believe.
It’s a group of them coming off that eeprom I mentioned on the buffer boards.
I removed 1 fro circuit and it was shorted. However the group of caps still all test short also.
Not sure how to find which one is bad or if it’s the eeprom except for removing each 1 by 1.
Old 03-08-2022, 11:56 AM   #8
diif
City & State: Midlands
My Country: England
I'm a: Professional Tech
Your photo is blurry but they look black not cap colour suggesting they are inductors and so will read as short.
diif is offline   Reply With Quote
Old 03-08-2022, 12:44 PM   #9
Storyteller12
My Country: USA
Quote:
I think you are correct. It’s getting harder to see these small things. Guess I’m getting old.
Old 03-08-2022, 04:18 PM   #10
captainKKK
City & State: Tx
My Country: United States
Have you checked the PS board? What are its voltages?
Where did you get the mainboard and tcon?
Have you had time to check t-con voltages?
captainKKK is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2022
Powered by vBulletin ®
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
