Garbage Find: Asus ET2203T - T9900 & Memory Upgrade
    Re: Most recent garbage find....
    Originally posted by Topcat View Post
    Yes, bumped a 5yr old thread only to update it... The HDD in this machine died again a couple months ago...I finally got around to fixing it. I replaced it with a SATA SSD this go-round. It also uses soDIMM's. I got curious and replaced the 2x 2GB modules with 2x 4GB modules, just to see if it could run that much...all the official online documentation says 4gb is the max. Well, they lied. 8gb runs flawlessly. I also abandoned WinXP on it and went with win7 pro, as the BIOS is SLIC'd. I was using this machine in my workroom...but when the HDD did the click of death, I replaced it with a Zotac Nano I320 fanless micro box & monitor, which will stay in place. This one will be re-appropriated for something else.
    The 8gb of ram & SSD with a nicely tweaked win7 install, it runs very nice.
    <----- Posted from this 5yr old trash can find!
    looking as sharp as it did the day you got it
      Ohh, and no....XP isn't an upgrade to Win7, its a GODSENT!!
      You sell-out!
      Lol, just joking with you TC. By the way, what is the Micron tower on the right side used for? We used to have lots of those Micron PCs with Pentium II and Pentium 3 CPUs back in middle school. I didn't know much about computers back then, but they seemed to be built pretty solid from what I remember.
        Originally posted by momaka View Post
        You sell-out!
        I backed off the Win7 hatred after SP1 came out, that really cleaned it up...and with classic shell, its very nice! I must admit, I really grew to love the aero+classic shell combo.
        That system is a supermicro X6 platform. Dual Paxville @ 2.8 w/ 16gb RAM. It's the last remaining netburst system in my fleet, and the only dual core netburst processors.
        <--- Badcaps.net Founder
        Badcaps.net Services:
        Motherboard Repair Services
        http://folding.stanford.edu/
        Team : 49813
        Join in!!
        Team Stats
          Yeah, TBH, I don't mind Windows 7 that much either. It more than likely will be my go-to OS when I need to upgrade my hardware to newer stuff sometime in the future. For now, most of my junky PCs have 1 GB of RAM (or thereabouts), so they are better suited with XP. And I still like the classic shell in XP just a little better than the classic shell in 7. They are similar, but I feel that XP classic is a little closer to the Win95/98/2000 look. Small things really, but you know how hard it can be to break old habits (double-right-clicking on a taskbar button to close an item in XP is one of them for me... IDK why they removed that in Windows 7).
          Ha, what a sleeper! Fooled me for sure.
          It's still more than decent, though - at least RAM-wise.
            Just another little footnote to this system....as Asus swears the only procesor it will run is the pre-configured T6600 2.2GHz 800FSB C2D....well we'll just see about that....since the CPU isn't hard mounted to the motherboard, its a nice purty pink socket-P!! Researching the Intel PM45 Express chipset revealed it supports 1066FSB and C2Q processors....The C2Q CPU was quickly ruled out, as the die config of the C2Q and the proprietary heat spreader & heatpipe of the system would not play nice with eachother....so I took a $40 gamble on a C2D T9900, the fastest C2D 1066FSB mobile processor available... Well it worked like a charm. POST'd right up @ 3.06/1066, and booted into windows without issue. I pasted the die nicely with some AS5, the T9900 doesn't run any hotter than the T6600, go figure. That was a nice upgrade with the faster FSB speed and larger caches....and now this machine is maxed out. Long live the C2 platform, and may this workhorse run another 5 years!!
            Team : 49813
            Join in!!
            Team Stats
              mos likely it didnt run anything else from the factory.
              asus has a habit of adding newer cpu's into the bios updates.
              something i wish all company's did!
                Re: Garbage Find: Asus ET2203T - T9900 & Memory Upgrade
                I naturally put the lastest BIOS on it before I started. I had no trouble upgrading this little baby. For what it is, its damn snappy with the SSD, RAM, and CPU upgrades, 3 small things that made a HUGE improvement. I even fixed the thread title to reflect the mods, if anyone else out there has one of these machines and wants to get a little more use from it.....google will point them to this thread.
                FWIW, I got this thread from 6 pages down to 2 after removing the OS arguments & bickering....
                Team : 49813
                Join in!!
                Team Stats
                  Hello just asking a question on your Asus AIO.
                  I know some one with a slow AIO pc.
                  The hard drive a 3.5" is a Toshiba DT01ACA100.
                  Crystal disk info "Caution"
                  AMD Radeon HD 8550G
                  AMD a8-5550M
                  asus all in one PC
                  Model: ET2221A
                  What do I do to speed it up and make it better. The internet was slow, had a USA time clock and not the UK, it is used in UK.
                  How do I replace hard drive to SSD.
                  http://www.hse.gov.uk/pubns/indg305.pdf
                    AMD Radeon HD 8550G
                    AMD a8-5550M
                    asus all in one PC
                    Model: ET2221A
                    The drive is failing. You're going to want to swap out the failing HDD for a new SSD, and reinstall Windows and all applications back onto it.
                    Permanently Retired Systems:
                    Kooky and Kool Systems
                    sigpic
                      AMD Radeon HD 8550G
                      AMD a8-5550M
                      asus all in one PC
                      Model: ET2221A
                      I don't know about the ET2221 versus the 2203, but the 2203 isn't fun to disassemble. Lots of tiny screws.
                      Yes a SSD will make the world of difference, also check and see if RAM & CPU can be upgraded (like the 2203 could be). I didn't know the UK used a different clock than the US....
                      FWIW, I tossed S2K12 R2 on this machine, carved into workstation mode.....it runs awesome!
                      Team : 49813
                      Join in!!
                      Team Stats
                        How do you open this computer up and replace the hard drive Topcat?
                        Also Acronis True Image WD version does not detect Sandisk SSD from the bootable media of Acronis.
                        https://www.asus.com/uk/support/FAQ/1012002/
                        https://www.youtube.com/watch?v=vmhZ0ytpruw is this how?
                          Looks like the Core 2 Duo T6600 is a laptop version of a Core 2 Duo E4500.
                          (2.20 Ghz)
                          ASRock B550 PG Velocita
                          Ryzen 9 "Vermeer" 5900X
                          16 GB AData XPG Spectrix D41
                          eVGA Supernova G3 750W
                          Alienware AW3423DWF OLED
                            " Also Acronis True Image WD version does not detect Sandisk SSD from the bootable media of Acronis."
                            Acronis True Image WD will recognize a WD drive. I ran into that issue a few years ago. Any True Image (drive mfr) edition must have at least 1 drive by that manufacturer.
                            Stupidity should be a crime, especially for drivers. I have NO patience for them.
                              So a WD laptop hard drive in a usb caddy will it work. detect the sandisk SSD.
                              Sandisk is made by WD.
                              What about the paid version of Acronis, will that detect the SSD.
                                Try this, worked well for me in the past when I've swapped hard drives to solid state drives.
                                https://www.easeus.com/backup-utilit...g-windows.html
                                  is that laptop CPU upgradable or soldered in? I find most AIO's are soldered, but sometimes medium-level ones are replaceable. T6600, Socket, Socket P
                                  if the 7 series works you could get a T7700
                                  https://www.ebay.com/itm/Intel-Core2...8AAOSweRlas8FV
                                  or maybe T7800
                                  https://www.ebay.com/sch/i.html?_fro...T7800&_sacat=0
                                  Might be able to take a 1066 fsb chip because the PM45 chipset supports it, in which case you could get up to some serious T9xxx series
                                    or maybe T7800
                                    https://www.badcaps.net/forum/showpo...3&postcount=25
                                    Already covered that one.
                                    Team : 49813
                                    Join in!!
                                    Team Stats
                                      Oh I looked didn't see that post. Doops
                                      Yeah they're both 35w tdp, one won't run any hotter, but it will stay at the higher threshold longer
                                        @Topcat, I have the same model Asus (except that I wasn't lucky enough to find mine--I paid $800 for it). It's three desktops old at this point but I can't bear to part with it. It's useful for watching Netflix. I did the same CPU upgrade that you did, and I upgraded the wireless card. It's running Windows 10 64-bit but it chugs. I also found (miraculously) a 4GB SoDIMM for less than $20 that will put the RAM at 6GB total (won't be fully dual channel but better than just 4GB for now).
                                        The real issue has been the hard drive. I have tried in vain to upgrade to an SSD but had no luck.* The chipset doesn't support AHCI.**
                                        I see that you were able to upgrade to an SSD. Which model SSD did you use? Are you using the Enhanced or Compatible controller setting in the bios? Finally, did you use an F6 driver during Windows setup?
                                        This is my first post on the forum here--thanks for all the great info! And for allowing me to respond four years later to your post from five years later, haha.
                                        *link: **********
                                        **link: ******************
                                          Oops... wrong link above (and I can't edit my post). The first link should be:
                                          *link: https://linustechtips.com/topic/8887...ergic-to-ssds/
