LENOVO NM-A841 Missing 5v/3v voltages
    Re: LENOVO Missing 5v/3v voltages
    Originally posted by SMDFlea View Post
    Have you found any resistors connected to the pin 11 trace or does it go into a via through the board ? A board view would help but I'm not sure if it's available. Take a picture of pu401 with the surrounding parts
    gos via the board sir
      According to the nm-a841 schematic no ,but schematics aren't always right even though you expect them to be. It can't be 19v on pin 11. Let's gets other members views and fix this together
      If you look at datasheet abs max Volt of en is 25v
      I read it wrong?
          I read it wrong?
          There is no datasheet for the SY8286BRAC .
            I read a post on a russian forum that pin 11 is indeed 19V .Just to be sure though inject voltage voltage on theat but but keep it low and slowly crank the voltage up.If you can get up to 19V then run a jumper between 2,3,4, or 5 to 11
              jumper on pin 11 checking voltage on all pins
              PU401
              PIN1- 0V
              PIN2,3,4,5 - 19V
              PIN6 0V
              PIN7 0V
              PIN8 0V
              PIN9 0V
              PIN 10 0V
              PIN 11 19V
              PIN12- 0V
              PIN13-0V
              PIN14-0V
              PIN15-1.3V
              PIN16 - 0V
              PIN17- 0V
              PIN18-0V
              PIN19-0V
              PIN20-0V
              PU301
              PIN1 - 19V
              PIN2 - 19V
              PIN3 - 19V
              PIN4 - 19V
              PIN5 - 19V
              PIN6 - 5.8V
              PIN7- 0V
              PIN8 -0V
              PIN9-0V
              PIN10-0V
              PIN11-0V
              PIN12-19V
              PIN13-19V
              PIN14 -19V
              PIN15- 5.8V
              PIN 16- 0V
              PIN13
                Pu301 is ok
                Change pu401
                Check capacitor pc422
                Apply 3.3v with dc at pc422 and check with multimeter voltage drops or stable if stable change pu401
                  Pu301 is ok
                  Change pu401
                  I dont have a pu401 right now sir\ do i need to remove it beore adding voltage on pc422?
                    Yes remove it
                      Yes remove it
                      nothing is consuming at pc422 capacitor sir 3.3v no amp
                        Confirmed
                        Change pu401 and likely KBC as well
                          Confirmed
                          its ha s same problem with my acer hehehe
                            Confirmed
                            Good day sir I hope you can help me again I already cahnge the PU401 ic but I got the same reading on all pins
                            PU401
                            PIN1 - 0V
                            PIN2 - 19V
                            PIN3 - 19V
                            PIN4 - 19V
                            PIN5 - 19V
                            PIN6 - 0V
                            PIN7 - 0V
                            PIN8 -0V
                            PIN9 -0V
                            PIN10 -0V
                            PIN11 -19V
                            PIN12 -0V
                            PIN13- 0V
                            PIN14 -0V
                            PIN15 - 0V
                            PIN16 - 0V
                            PIN17 - 0V
                            PIN18 - 0V
                            PIN19 - 0V
                            PIN20 - 0V
                            ive tested the impedance of PL401 7KOHMS
                            PL402 27 Kohms is this normal sir?
