List of pin compatible Laptop ICs
This is a sticky topic.
    Re: List of pin compatible Laptop ICs
    Current max same
    Voltage range same
    Socket sot 23,-5
    But pin configuration different
    Data sheet attached check
      does anyone know an equivalent for ISL88739HRZ
      thanks
        What is the stac9200x5 counterpart?
          I have replaced RT8207A on Quanta HK1 with G5616R52U from Quanta HK5 since surrounding components were almost entirely identical.
          Everything is ok on HK1 with G5616R52U.
            ALC 662 equivalent ?
              Isl6265c algun equivalente?
                TPS22966DPUR - APE8990GN3B compatible (LA-A994P U18)
                  5X=4F 3v 5v alw is a ?
                    Originally posted by jasko_jacker View Post
                    5x=4f 3v 5v alw is a ?
                    rt6575dgqw 5x=
                    https://bomcross.ti.com/en/search?se...5dgqw&qty=1000
                    TPS51275B-1RUKR
                    https://cdn.badcaps-static.com/pdfs/...a3ab1be060.pdf
                        It's used in conjunction with bq24780s on asus motherboard as upgrade of
                        tps1285a , someone can confirm this cross reference ?
                          Are you asking for a compatible part for the tps1285a or asking if its compatible with the TPS51275B / rt6575dgqw ?
                          The richtek cross reference says the RT6585A is compatible with the tps51285a .It says B2B meaning its a Fully drop-in replacement. Check both datasheets though to make sure
                          https://www.richtek.com/Design%20Sup...ss%20Reference
                          RT6585A marking code 3J=
                          https://cdn.badcaps-static.com/pdfs/...ae9d171f8c.pdf
                            8744e which one can be replace or compatible to replce?
                              Mosfet AO4409 can be replaced by AO4423.
                              I observed that the factory did this replacement in Dell Inspiron n5520.
                                Hello
                                Any help for replacement for BAAAIK Its near the Battery port on Lenovo V130-14ikb Mainboard LA-F486p Rev 1.0 or if anyone has Schematics for it.
                                Thanks B.R.
                                  Sorry for LQ Picture
                                    Originally posted by elvirpa800 View Post
                                    Hello
                                    Thanks B.R.
                                    Schematic - https://www.badcaps.net/forum/showthread.php?p=1060162
                                    https://www.badcaps.net/forum/showpo...1&postcount=12
                                    BAA*** SY8286RAC
                                    No cross compatible part afaik .
                                      Thank you very Mouch bro,you saved me ...
                                        what is the alternative ic for BQ24780RUYR?
                                          RTD2136R IC equivalent
                                          hi everybody i need equivalent for this IC RTD2136R plz
