Bose mini soundlink
    Bose mini soundlink
    I have a bose mini 1 soundlink, the older version 6 buttons that has stopped working, shows only a red light. I replaced the battery of this with another one from a working unit, but this still shows red light.
    Unfortunately no schematic or any other information is available on this.
    I would like to fix it and use it without the battery, which is very expensive
    and I do not need it.
    So far I can see this has a battery regulator ic bq24172 and another ic 564( unable locate any data on this), three mosfets k7k, on the charger input board.
    The ic 564 has 6 pins (three on each side) would appreciate if anybody can help me identify it to get a datasheet.
    If any body has repaired these I shall be grateful for any help.
    Re: Bose mini soundlink
    Did you get anywhere with this please?
    I have a unit displaying the same fault.
    Thank you
      hope someone can help. I have the same issue.
