Aspire 6530G - no backlight!
    As the title says, I have a 6530G here (that has been recased by myself into a near-pristine 6930G casing) will power on just fine.
    The issue with it is that the backlight will not come on at all. Using a flashlight, I can see the laptop booting into Windows fine, and I do have external (HDMI) output.
    First off, a few specs:
    AMD Turion Ultra ZM-80 2.1GHz
    2GB DDR2 (667 I think)
    ATI Radeon Mobility HD4650 1GB - tested fine on another Acer (model 5520G, w/ MXM slot)
    Hitachi-LG GT30N
    Anyways, I have tested both the display and the inverter, and checked motherboard too.
    Results:
    -display works fine - tested on an Acer Aspire 5536G - backlight lights up.
    -tested inverter - I have the main 19V and ADJUST voltage, but no ENABLE voltage.
    -tested motherboard components responsible for the ENABLE signal - all tested up fine.
    -tested EACH inverter SMD component - all came up fine.
    Anything else I should try? I am at a loss at what else to try.
    Again, the GPU is working fine and so is the LCD itself (Samsung LTN160AT01), and the inverter seems to do its job (as I have read 19v straight from the pin on the inverter PCB) but I don't have any slight hint of the ENABLE signal on the inverter.
    Other useful data:
    MB model: Quanta ZK3 Rev:E
    Inverter model: Sumida IV10117T/C4-E-LF
    Main rig:
    Gigabyte B75M-D3H
    Core i5-3470 3.60GHz
    16GB DDR3-1600
    Samsung SH-224AB DVD-RW
    Delux MG760 case
    Re: Aspire 6530G - no backlight!
    If CN3 is your LVDS Connector check pin 10 1 5 2 voltage
      Yes, CN3 is LVDS.
      Pin 1: 10V
      Pin 2: 0V
      Pin 5: 3.3V
      Pin10: 1.16V
      Main rig:
      Gigabyte B75M-D3H
      16GB DDR3-1600
      Delux MG760 case
        Originally posted by Dan81 View Post
        Yes, CN3 is LVDS.
        Pin 1: 10V
        Pin 2: 0V
        Pin 5: 3.3V
        Pin10: 1.16V
        Now check U4 IC all pins expect 2/5 with power and with out power with the help of the multimeter resistance to ground all pins expect 2/5
          Okay, here are the readings, meter set to 2k for 1 and 3, meter set to to 200ohms for 6 and 4.
          No power:
          Pin1: 1.490kOhm
          Pin3: 1.274kOhm
          Pin6: 5Ohm
          Pin4: 5Ohm
          With power applied I get infinite on all pins, and that's with the meter set and tested on each setting - 2k,20k,200k and even 2M.
          I used one of the screws for the left hinge as GND reference.
          Main rig:
          Gigabyte B75M-D3H
          16GB DDR3-1600
          Delux MG760 case
            No power:
            Pin1: 1.490kOhm
            Pin3: 1.274kOhm
            Pin6: 5Ohm
            Pin4: 5Ohm
            Put the meter to 20V and test again Voltage on all pins of U4
              U4
              Pin1:3.21V
              Pin3:3.19V
              Pin6:3.26V
              Pin4:3.28V
              Main rig:
              Gigabyte B75M-D3H
              16GB DDR3-1600
              Delux MG760 case
                Pin 1 is have 3V but the CN3 pin 2 0V check the resistor R22 both sides for Voltage, The screen must be connected to the motherboard when you test
                  3.20V on both sides.
                  Main rig:
                  Gigabyte B75M-D3H
                  16GB DDR3-1600
                  Delux MG760 case
                    In Post#3 you have written 0V on pin 2 CN3! So now you have Voltage on pin 2 of CN3
                      Yeah, I now figured out why I had 0V first time and have 3.2V. The first time I tried to measure pin2 I had to remove the LVDS cable to have access to it. Dumb move from my part.
                      However, how do I check pin10 now? I successfully found out I have 9V on CN3 pins 1 and 3 (these are the main power to the inverter), 3.20V on pin 2.
                      L.E: I managed to measure pin10 through the pads of unpopulated R175. 1.68V measured.
                      Main rig:
                      Gigabyte B75M-D3H
                      16GB DDR3-1600
                      Delux MG760 case
                        Now test Pin 15 BL_ON and Pin5 +3V
                          Now test Pin 15 BL_ON and Pin5 +3V, For the Main power 10V is for Battery not for the adapter (+19V) leave it for the moment
                            Pin5: 3.3V
                            Pin 15: 0.54V
                            Main rig:
                            Gigabyte B75M-D3H
                            16GB DDR3-1600
                            Delux MG760 case
                              Pin5: 3.3V
                              Pin 15: 0.54V
                              This is your Backlight Control circuit check all voltage , pin 15 Voltage should be 3V-3.3V
                                R36: 3.24V
                                R37: 3.24V (both sides)
                                R35: 3.24V only on one side
                                R32: 3.27V only on one side
                                R34: 3.27V on one side, 0.53V on the other
                                Q8: no voltage on any pins
                                Q7: 3.22V on gate
                                Q5: 3.27V on Drain and Source
                                Q4: 0.51V on Drain, nothing on the others
                                D2: 0.51V on one side, 0V on the other
                                Pin 15 still sits at 0.51V.
                                Main rig:
                                Gigabyte B75M-D3H
                                16GB DDR3-1600
                                Delux MG760 case
                                  A photo with the voltages.
                                  At this point I am deciding whether to get another motherboard (a ZK2 this time, at least to put one of my T9400s to a good use) or just rig up a bunch of slim 5v LED strips behind the LCD.
                                  Main rig:
                                  Gigabyte B75M-D3H
                                  16GB DDR3-1600
                                  Delux MG760 case
                                    Any Other member could help why BL_ON 0.53V?
                                      no without detailed resistance measuring. i would check that LID signal
                                      post full schematic
                                      please wrote your reading for every pin of that mosfets in red color to picture.
                                      u must have BL# grounded by Q7/gate is high/ so it not grounded by next mosfet/gate is low/ BL_ON signal.
                                        post full schematic
                                        So if Q7 gate is grounded this enables the BL_ON signal?
                                        Main rig:
                                        Gigabyte B75M-D3H
                                        16GB DDR3-1600
                                        Delux MG760 case
