Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Audio Equipment Discussion
Thread Tools Display Modes
Old Yesterday, 03:17 PM   #41
R_J
City & State: ☻
My Country: Canada
I'm a: Professional Tech
Default Re: Philips FR-740 working but no audio output
It should'nt be hard to find a transitor to use for now, almost any pnp rated higher than 60v should work.
So with that transistor out of circuit do you have audio out of the speakers?
did the voltage on 7310 (C) drop a bit lower from before?
With that transistor out of circuit, any comand from the front panel should have no effect on turning the amp ic's on or off, so if there still is no audio (and you have it at the stk inputs) then that voltage on the CCC line must still be too high
R_J is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2018
Powered by vBulletin ®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
