That Thermaltake 430W PSU does look a little on the cheap side, but better than a L&C. Teapos are fine in a PSU, and I haven't seen a CapXon cap fail yet in a PSU.
That will do fine powering the VP6.
My gaming PC:
AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
ASUS M4A77TD AMD 770 AM3 Motherboard
PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
ASUS Xonar DG 5.1 Channel PCI sound card
Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
Antec Three Hundred Mid-Tower Case
Microsoft Windows 10 Pro 64-bit
Microsoft Windows 7 Ultimate SP1 64-bit
New supply is installed and the voltage numbers look almost exactly like the Antec power supply's numbers.
But no wierd noise.
The "2.5v is too higher" message still comes up when enabled. It's obvious that it's not the fault of the power supply.
Here's a question: When you use a new style supply to power a slightly older board could it cause an unexpected voltage levels? I noticed that the ATX standard developed to the point where a certain wire is no longer required (it was dropped from the ATX spec).
......someone forgot to pack that little red arrow with my new power supply.
I've seen some new power supplies missing IIRC the white +5VSB wire on the ATX connector. I have four ATX power supplies like that, and the missing 5VSB wire won't hurt the motherboard at all. They didn't damage my old trusty AOpen AX6BC Slot 1 motherboard (that board came stock with United Chemi-Con caps, wow for a board made in 1999! ).
My gaming PC:
i put the old via monitor on a customers box today and got the same error including the engrish.
freshly recapped vp6 with tc's modded bios.
its a non issue.
Those CPU coolers I mentioned from computergate are $7.95 each or $7.75 each for two or more. They have to be better than the stock Intel heatsinks with the green clips. And I agree, the VIA monitor abnormal voltage warning seems irrelevant and/or wrong.
2.5v (if it's even used) is most likely for some part of the chipset.
Can't be sure.
Unlike Intel's chipsets, diagrams of VIA chipsets aren't so easy to find.
Mann-Made Global Warming. - We should be more concerned about the Intellectual Climate.
Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind. - Dr Seuss - You can teach a man to fish and feed him for life, but if he can't handle sushi you must also teach him to cook.
The white wire is -5V, not 5Vsb (that's purple).
I think -5v is only used by some ISA cards (and apparently not many even of those). It's in the ISA pinout anyway.
gdement's right.
I've heard mention that some transitional MSI boards (about the time ISA slots were going away) used -5v on the board for something or other. My guess it that they didn't have an ISA slot but the board still had a legacy ISA BUS with some chip on it that needed -5v. (Maybe like a sound chip? - Not sure.)
I've never seen an Abit VP6 that uses DDR.
Have you?
