Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Computer Displays
Thread Tools Display Modes
Prev Previous Post   Next Post Next
Old 11-23-2015, 08:15 PM   #40
sambul83
City & State: London, ON
My Country: Canada
I'm a: Knowledge Seeker
Default Re: Westinghouse L2410NM No Power, No LED
After some time running with the new power board, the monitor flickering seems to decrease to just 3-4 times a day. I noticed, heavy flickering starts when the monitor's back is under direct sun light. This means, one of major causes is definitely HDMI chipset overheating. There seems to be 2 identical chipsets despite only 1 HDMI port, may be another one for VGA port, or analogs?
I want to put a fan just above the 2 chipsets with heatsinks. Would you suggest to use a 5V or 12V fan for this application? The power supply gives 5.8V, 10.8V, 3V to the main board, also 3V and 25V on the other side to the inverter board. Did I hook it right to the power supply? Is there any difference from which terminals it will be powered on, since there're several with the same voltages? The monitor doesn't have sleep mode by design, it goes to blue screen low power mode when the PC goes to sleep, so how it will affect the fan spinning?
Or may be you can suggest a better location, orientation, or fan type, since I've several? In this orientation, airflow will hit partially (half) overlapping section of the plastic back cover placed just above the metal cage. Another location can be between the power supply and main board standing and directed along the air flow from the monitor's bottom to top, but the fan must be smaller size, possibly higher RPM.
sambul83 is offline   Reply With Quote
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2019
Powered by vBulletin ®
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
