Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Desktop Motherboards, Graphics Cards, and PC Peripherals
Thread Tools Display Modes
Old 12-29-2010, 05:22 PM   #1
enduser
Exclamation Dell Dimension 4700 - Bad United Chemi-Con
I was hired to troubleshoot a Dell Dimension 4700 PC that kept having random keyboard errors. I checked the BIOS log and noticed it had multiple errors with not only the keyboard but also with the memory, mouse, fan, etc.
I opened the cover to clean it figuring the heavy dust buildup was causing the CPU to overheat and generating these random errors. After blowing the dust out I found two United Chemi-Con caps leaking oil and with bulging tops.
The only two caps one each of the KZG, and KZJ series on the whole motherboard were bad. All other caps by United Chemi-Con are of the KZE series and are good.
New caps ordered will update when I install them.
2200uF 6.3vdc KZJ 105C, and 3300uF 6.3vdc KZG 105C
enduser is offline   Reply With Quote
Old 12-30-2010, 03:22 AM   #2
yyonline
City & State: Pennsylvania
My Country: USA
Default Re: Dell Dimension 4700 - Bad United Chemi-Con
Check the fan direction. Dell installed the case/cpu fan to blow IN. According to Dell, this is deliberate and correct. They even have a page dedicated to the issue warning you not to change it:
http://support.dell.com/support/topi...&isLegacy=true
However, in my experience, every 4700 I've worked on runs cooler with the fan blowing out in the traditional direction. Take from that what you will.
yyonline is offline   Reply With Quote
Old 12-30-2010, 04:58 AM   #3
Th3_uN1Qu3
Believe in
City & State: Bucharest
My Country: Romania
Line Voltage: 230VAC 50Hz
I'm a: Professional Tech
An inwards blowing fan was standard with old AT power supplies... till they figured out it gathers WAY too much dust this way. So i second the recommendation to flip it around.
__________________
Quote:
Originally Posted by PeteS in CA View Post
A working TV? How boring!
Th3_uN1Qu3 is offline   Reply With Quote
Old 12-30-2010, 05:09 AM   #4
c_hegge
c_hegge's Avatar
City & State: North Coast, NSW
My Country: Australia
Line Voltage: 240V 50Hz
It's one of those cases where DELL = Doesn't Ever Last Long
__________________
c_hegge is offline   Reply With Quote
Old 12-30-2010, 06:04 AM   #5
japlytic
japlytic's Avatar
City & State: Rockhampton, Queensland, Australia
Line Voltage: 240VAC 50Hz
I'm a: Hobbyist
Quote:
Originally Posted by c_hegge View Post
it's one of those cases where dell = doesn't ever last long
__________________
japlytic is offline   Reply With Quote
Old 12-30-2010, 08:31 AM   #6
styxbound
Enduser, there is a transistor just to the left of the power supply socket by an inductor, Q5H1. Can you tell me the number of that? Took it out then lost it before I got the number. Thanks.
styxbound is offline   Reply With Quote
Old 12-30-2010, 07:11 PM   #7
enduser
Quote:
It is made by ON semiconductor the numbers on it are shown as follows:
441 ON
T
11ON2
Old 12-30-2010, 07:14 PM   #8
Th3_uN1Qu3
Believe in
My Country: Romania
Mmm, isn't that 110N2 and Infineon? http://www.alldatasheet.com/view.jsp?Searchword=110N2
Old 12-30-2010, 08:09 PM   #9
styxbound
Hey thanks, guys. Thought I was going to have to wait until I run across another of these things.
Old 01-14-2011, 08:32 PM   #10
enduser
Just like to update and confirm that replacing the mentioned caps fixed this motherboard. I replaced those caps with the Panasonic low-esr series
Old 01-14-2011, 08:34 PM   #11
enduser
Quote:
Thanks for the correction, I was not aware of this brand.
Old 01-15-2011, 05:50 AM   #12
Th3_uN1Qu3
Believe in
My Country: Romania
Infineon makes A LOT of motherboard mosfets. Some memory chips too.
Old 01-16-2011, 12:39 PM   #13
Lew
City & State: Florida
Question Re: Dell Dimension 4700 - Bad United Chemi-Con
Hey enduser. I'm working on a friend's a Dell Dimension 4700 that has at least one bulging capacitor and the same symptoms you've described. I've removed all the motherboard retaining screws but the motherboard isn't releasing. It seem to be held near the CPU. Do you remember there being a hidden screw under the CPU heatsink? I didn't want to remove and re-seat the heatsink unless necessary.
Lew is offline   Reply With Quote
Old 01-16-2011, 01:58 PM   #14
yyonline
My Country: USA
Yes, almost all Dell Socket 775 CPU brackets screw to the case chassis. You're going to need to pull the heatsink. Under that there are 4 screws holding on the plastic retention bracket. Remove those and the motherboard should come out.
Old 01-20-2011, 06:58 PM   #15
Lew
Thumbs up Re: Dell Dimension 4700 - Bad United Chemi-Con
Replacing the 2200uF 6.3v KZJ located by the RAM slots solved the rebooting/stability problem with my friend's Dimension 4700. Works like a charm now!!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2020
Powered by vBulletin ®
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
