Hey guys,
I have a Vizio P502ui-B1E with no display activity at all with the power light on. It broke in a very specific way, and now exhibits strange behavior when turned on (slow response to power off command, restarts every 90 sec, more below), so I'm hoping that someone with experience working on this TV can point me in the right direction.
I already tried the 2 most common fixes with no luck:
- Replacing the T-Con board.
- Re-flashing the firmware on the U202 chip (from here: https://www.badcaps.net/forum/showthread.php?p=840012)
Here's exactly how the TV broke:
About an hour into watching a show in 4K resolution, the right half of the picture turned into colorful pink-ish noise (at the pixel level). The left half of the picture was completely normal and the TV was responding to remote control input normally. The picture corruption affected all inputs and even the on-screen-display menus drawn by the TV itself. After about 30 seconds, I turned the TV off with the remote control, in an attempt to reset it. It turned off normally. It would not properly turn on again.
Here's the current state of the TV (starting with plugging in the power cord):
Less than a second after the power cord is plugged in, power is applied to the USB port for about a second. Less than a second later, power is applied to the USB port again, also for about a second, and, at the same time, the white power light (bottom-left of the TV) turns on bright. A few seconds later, the power light starts slowly dimming and soon turns off. TV is now in standby. This startup sequence is normal, as far as I know.
When the power button is pressed on the back (or the remote), the power light immediately turns on bright. Less than a second later, a 1-second burst of power is applied to the USB port. Less than a second later, power starts being applied to the USB port continuously. This sequence is also normal up to this point.
At this point, the screen would normally turn on and show the Vizio logo, but the screen stays dark. The power light dims to low a few seconds later (this part is normal). The TV does not appear to properly respond to inputs at this point - pressing the power button (either on the remote or on the back of the TV) does not turn the TV off immediately. It will only turn off after a random period of about 5-60 seconds. If left in the powered on state, the TV will also reboot exactly every 90 seconds forever (by reboot, I mean the power light turns bright, power disappears from the USB port for a few seconds, then the sequence of events restarts as in the previous paragraph). During this sequence, the bottom processor on the main board (MIPS) generates plenty of heat while the top one (FRCX) only generates a little.
Interestingly, the TV behaves the in the exact same way (previous 3 paragraphs), no matter what is connected to the main board. If I disconnect all cables (except power input and power button/ir circuit), and even desolder the U202 firmware chip, the TV will behave in the EXACT same way.
So what should I look for next? Both processors have what look like a JTAG and an I2c interface on the main board. Any way to talk to them maybe? Thanks for any ideas!
