Eeprom dump thread!
This is a sticky topic.
    Re: Eeprom dump thread!
    Originally posted by deann View Post
    Hi guys. I have a Philips 50PFL3008H/12 with a V500HJ1-LE1 panel and a 17MB95S-1 (23140890) mainboard. The EEPROM failed and it seems I cannot find ANYWHERE the .bin file. I would really appreciate your help.
    Thank you.
    hi man tv proplem?Does the standby LED flash?
    17mb91s-1 have toshiba and vestel software.
    spi flash dump No way.nand flash software is corrupted.
    standby flashing led philips support check it http://www.p4c.philips.com/cgi-bin/d...=50PFL3008H/12
      Originally posted by Duranitron View Post
      Need help here guys! any one have the eeprom dump of LG 43lf5400-TB?
      thanks..
      What is tv proplem
      software here https://www.lg.com/africa/support/su...3LF5400-TB.Did you try?
      43lf5400 mx25l8035 spi flash I have a dump https://we.tl/t-8hkB600GkE
        Thank you.
        try
          Does anyone have a dump for
          Sceptre
          Model----X322BV-HD*CK12BW2
          Main Board---T.RSC8.10B 12305
          A12081963
          T315CK12-BW2
          Panel----DTW0315CK12-A
            Originally posted by d2fx View Post
            I need the dump for coby ledtv3226 please.
            panel Samsung LTA320AN01
            best regards
            https://www.badcaps.net/forum/attach...1&d=1548981286
              Originally posted by dani502017 View Post
              I honestly do not have the time to edit hundreds of archives, who needs the software to write to me what she needs, danirestaurari@yahoo.com my mail. Most of the software is for tv 2010-2018
              When I have time, I will also climb the forum.
              All good to everyone.
              Please I need Samsung UA40J5100AR bin file. Cheers and Thanks.
                model is LG 43LF5400-tb thanks for the eeprom dump ayhan yılmaz i reflash it using my ezp2010 with no luck.. still the same symptoms.. no video no sound but with backlight.. the tv can be turn on and off by remote control.. do i need to replace the main board.. the XD lge 2136 is heating up.. any help.. thanks again.
                Never stop LEARNING because life never stops TEACHING!
                  panel ? main?
                    try this file LG-49LF5400 https://we.tl/t-X15qor6ph2
                    check the motherboard first.mainboard stnby is checking the.5v normal.3.3 normal
                    Is there a panel (matrix) ticon card voltage ?.
                    Remove the motherboard and panel (matrix) lvds socket
                    cpu XD lge 2136 Is there temperature.If too much temperature cpu If the temperature is normal.panel (matrix) error.
                      Sceptre
                      A12081963
                      T315CK12-BW2
                      hi my friend dump I made the request.Private file will take some time I'm waiting
                        all voltage are correct in allowable value..the lge 2136 is heating up.. decided to reflow it using my bga rework station w/ flux RMA223 heating it up to 190c and using the nudge test to ensure all solder melts. if its doesnt cure it. ill post it.. and if you have any idea or tips pls. let me know bfore i throw this board..
                          not a thing.. same symptoms. ready to throw this mainboard. no video, no sounds just backlight is lit when you turn on the tv can also be turn off by RC. what i've done.. check all the voltage based on the service manual, reflash the eeprom with new data, reflow the LGE 2136. maybe the LGE 2136 is defective.. any one have a spare 43lf5400-tb mainboard?
                            im sorry forgot to mention.. this tv was struck by lightning via cable to the HDMI port.. no visible physical damage. costumer said that while watching they heard a loud thunder just outside and instantly the TV turns off, and when they turn it on just backlight is lit..
                              Mainboard bloka
                                try
                                Thanks dani502017, that's the one!!
                                I have many dumps (Samsung/LG/Philips) I'll try to upload them in here ASAP.
                                Thanks again Dani you rock!!
                                  Thanks, but the NAND is new and I flashed it with the original soft.
                                  I needed the dump for the MX and it's already solved.
                                    Mainboard bloka
                                    thanks for the help , yesterday i bought the mainboard and placed it and instantly it was restored..much appreciation guys..
                                      model alphasonics
                                      dump t.msd309.b62s
                                      panel M185XTN0 1.2
                                      thanks
                                        It is not fair not to post here the software, maybe there are others who need it.
                                        I want to say big big thank you to dani502017. The TV is back to life again.
                                        You are rock, Daniel
                                          model alphasonics
                                          dump t.msd309.b62s
                                          panel M185XTN0 1.2
                                          thanks
                                          I have for t.msd309.b62s but different display. I suggest you drop the memory cool it with a cooling spray and see if you can copy the contents then rewrite it on a new memory.
