Hi. I've been trying to learn how to build electronic circuits. I've been using a tutorial I found on the net (http://www.physicsclassroom.com/clas...ial-Difference) and I'm getting a little confused. I'm trying to understand exactly what a coulomb and an ampere is. I've googled it and came across these definitions:
A coulomb is a unit of electric charge, equal to the quantity of electricity conveyed in one second by a current of one ampere.
An ampere is a unit of electric current equal to a flow of one coulomb per second. Essentially, the rate of electron flow or current in a conductor.
This is where I get confused. A coulomb is the amount of charge that passes a given point when 1 ampere of current passes through that point in one second. If you replace the word ampere with the definition of ampere, it gets a bit confusing.
A coulomb is the amount of charge that passes a given point when a unit of electric current equal to a flow of one coulomb per second of current passes through that point in one second.
You see where I'm getting confused? The definition of a coulomb talks about amperes and the definition of amperes talks about coulombs. Could someone please help me understand what exactly a coulomb is? Thank you.
