Hi
I rec'd this board and it appears to have been working ok until recently.
The system randomly locks up at arbitrary times. I have replaced the
PSU with an Enermax 550W but the problem persists.
It's beginning to brown me off!
So...
I took the mobo out of the case and gave it a visual inspection.
Suprisingly, I did not find any bad caps or rather, evidence of caps
failing as they all appear to be in good condition.
However, what I did find much to my surprise was the area on
the underside of the board where the AMD northbridge and
CPU voltage regulator reside topside are tinged slightly brown.
First, the area under one of the power MOSFETS appears to be
the worst as well as a noticable discolouration under the north
bridge (an AMD 761).
When I rec'd the board the fan on the n/bridge was dead and I
replaced it with a good papst. The fan runs ok and MBM5 reports
the IC as being only 20 degrees celsius. Is this colouration evidence of o/clock or fan failure?
Can anybody offer any advice as to the status of the power device?
The system will power up ok and it is only whilst using does it lock up.
Alternatively, as this board offers a raft of o/clock settings via DIP
switches in the board - has it been seriously o/c'ed?
Myself, I have been using this mobo as a desktop with an AGP Pro card
and thought, after some research, the problem was with the on-board
Promise Lite RAID controller as it known to be problematic. For my part,
I disabled it entirely and installed a Promise SuperTrak 100 6-ch H/W
RAID controller. Problem still persists.
Lastly, I reviewed the area of the memory slots on the mobo and found
one SMT cap (C252) was missing. I do not know the value of this device
and hope someone can help. Interestingly, over the period I was trying to
resolve the fault, I had tested the 3 x 512MB PC2100 Reg ECC DIMMS
installed on the board with Memtest 86 v3.3 for three hours and it reported no faults.
Any help and advice greatly appreciated.
So...
