Need bios & ec from BDL50 LA-D704P REV:4.0 for HP
    Hello, I need bios & ec , board BDL50 LA-D704P REV:4.0, HP laptops.
    I replace kbc KB9022Q D, kbc short circuit line 3,3V.
    Regards.
    Re: Need bios & ec from BDL50 LA-D704P REV:4.0 for HP
    Post your bios backup, and give laptop model number such as 15-bd003tx.
      I have only board, I will get the data and give it. Thank you.
        https://*******************/product/hp-15-bd-la-d704p/
          Ok .The bios update has 5 different bios versions,so your bios backup is needed to check which one is the right one.
            bios for HP 250 G5 / Product: Z3A54ES#AKD
            I will try it in a few hours, now other works.
              my bios :
              https://www.badcaps.net/forum/attach...1&d=1555339208
              bios from ardeyalex not work, after push power button current power ~10-20mA, i not sure is board ok, i had to replace KB9022Q
                Here`s your bios,its a full bios extracted from the hp update with your win key added.
                  Still wrong, I think so problem hardware. After push power buton UC1 not read UC2 (25B64), 3,3V ok, no clk pin7, oscillations YC2 UC1 ok. Or wrong EC 128kb in KB9022 inside memory, is possible ?
                  I hope that I will be understood.
                    It could be the KB9022.Most of the ITE,Nuvoton,ENE chips for sale are used .
                      Here is the EC , its cut from the bios i posted .bios id BID081EC .
                      The other bios id`s are on another post for anyone else looking,there are 5 different bios id`s for the LA-D703P and LA-D704P
                      https://www.badcaps.net/forum/showthread.php?p=739852 Post #9
                        hi bros......any one has la-d704 io programming connection points details
                          HP 15-be012tu bdl50 la-d704p rev 4.0
                          Need Bios dump AND KBC HP 15-be012tu
                          MOTHERBOARD : bdl50 la-d704p rev 4.0
                          CPU : SR2UW Intel i3-6006U
                          GPU NONE ONLY INTEL
                          KBC : ENE KB9022Q D
                          MY ORYGINAL BIOS DUMP HERE
                            Re: HP 15-be012tu bdl50 la-d704p rev 4.0
                            try post#14
                            https://www.badcaps.net/forum/showthread.php?t=57159
                              Originally posted by peste View Post
                              no change. black screen
                                try
                                  try...
                                    I'll check tommorow
                                      Originally posted by piszpunta View Post
                                      I'll check tommorow
                                      try..
                                        try..
                                        No change
                                        maybe this is KBC??
                                        my oryginal KBC dump here:
