HP ZBook 17 G2 Locked BIOS Dump
    Hey everyone. New to the forum and to reading/writing chips in general.
    I recently purchased an HP ZBook 17 G2 without any knowledge that there was a BIOS administrator password on the machine. After lots of research, looks like either an smc.bin or manipulation of a BIOS dump are the only 2 options.
    I have used the Mazzif utility in the past with success on older laptops but as we all know it doesn't work on anything newer.
    Attached is my BIOS Admin password locked dump file. The chip is a Winbond 25Q128FVSQ.
    Laptop: HP ZBook 17 G2
    BIOS Version: 1.17 (07/13/2017)
    Motherboard: LA-B391P Rev. 1.0
    Quadro K4100M Graphics
    Please let me know if this can be unlocked or if I missed anything and more info is needed!
    Much appreciated!
    -Mike
    Re: HP ZBook 17 G2 Locked BIOS Dump
    Much appreciated!
    -Mike
    Try
      Originally posted by CraterM View Post
      Try
      I will try later today. I'm not sure if my original dump that I uploaded was 100% good.. last night I erased the BIOS chip and tried to program back the locked backup and now the system won't POST.
      I used a CH341a programmer to make the dump and to erase/write. I also have an EZP2019 programmer but could not get it to recognize the chip.
        Unfortunately no luck - I think my CH314a programmer isn't working properly. It takes a lot of tries to get it to connect properly using the chip clip. Once I finally do get a connection and it detects the chip it allows me to read, erase, blank, and write. However it will not verify correctly.
        Can anyone recommend a better programmer that isn't super expensive?
        Edit: I have tried software versions 1.13, 1.18, 1.29, 1.30, and 1.34. Only versions 1.29 and newer detects my chip properly but all the versions produce the same result.
          try..TL866A,CS,ETC..
            ch341a works perfectly with 25Q128FVSQ - use AsProgrammer:
            https://www.badcaps.net/forum/showpo...6&postcount=10
            Become a Badcaps supporter
            Thanks to all supporters.​
              MY MAN!!! You just saved me from a week of stress. AsProgrammer software worked like a charm. And the unlocked BIOS file also worked - BIOS is now unlocked.
              Thank you guys very much!
                Congratulations, well done.
                Cheers
                I know, I know...
                Good job.
                  Try
                  Thanks you very much, it worked perfect for my zbook g2, i have reflash bios chip with CH341a in minutes (most complicated parts was to have good connection whit chip clamp ^^)
                  I'm so happy to unlock this computer after days of research !!!
                    HP ZBook 17 G2 Locked BIOS Administrator
                    Hi All,
                    New to the forum and to reading & writing BIOS chips.
                    I brought an HP Zbook 17 G2 from eBay and discovered that it has a BIOS Administrator password. Got nowhere googling and HP do not supply smc.bin files to unlock the system.
                    I think I managed to get a bios dump from the machine. The programmer identified the bios as W25Q128.V (16384 kB, SPI). I have attached this in the hopes it is useful.
                    Laptop: HP Zbook 17 G2
                    Bios Version: M70 Ver. 01.24
                    Please let me know if this laptop can be unlocked or if I need to supply more details.
                    Thanks,
                    Paul.
                      Re: HP ZBook 17 G2 Locked BIOS Administrator
                      try and report
                        Thanks for your response. I managed to get the chip flashed ( took many attempts to get a good attachment with the clip ). Unfortunately whilst flashrom wrote and verified the chip, I could not start the laptop. It flashes a few times, then the fan kicks in and it sits there - nothing on the screen.
                        Maybe I got the wrong chip? Or have to reset something else.
                        There is another winbond chip on the motherboard. I have attached that dump file just in case.
                        I'm open to any suggestions!
                        Thanks,
                        Paul.
                          Thanks,
                          Paul.
                          The file that i upload it was your file with password cleared. Just flash the first chip and try. If that not work, use other bios chip (same specs). After this if still not work I think that you damage the mainboard.
                            Default HP ZBook 17 G2 Locked BIOS Dump
                            Thank you very much!
                              Re: Default HP ZBook 17 G2 Locked BIOS Dump
                              try..
                                thx
                                  HP ZBook 17 G2 Bios Locked - strange dump
                                  I have locked bios with admin password and additionally the following message:
                                  "The embedded Controller MUD data is not valid while MPM is locked. Please unlock MPM, and lock again to capture valid MUD data."
                                  I already deleted some bios passwords on zbook g1/2 and with deleting the string "biosUser00" and following with just reading/flashing the downside 25Q128 chip.
                                  This time it's different. There is no string (BIOSUser00) in the dump. I reread several times so I think the dump is OK. I desoldered and did not read in circuit. I additionally read (in circuit) the top side 25Q128 chip. Not sure if it is needed. I would be happy for any help:
                                    Re: HP ZBook 17 G2 Bios Locked - strange dump
                                    try..
                                      Thy for the file. After flashing your file the notebook is not booting anymore. I just see flashing caps lock.
                                      EDIT: definitely bricked now, even with original dump...
                                        EDITeleted
