Badcaps.net Forum
Go Back   Badcaps Forums > Motherboards with Bad Capacitors > Abit - Asus - Aopen
Thread Tools Display Modes
Old 06-28-2017, 07:38 AM   #1
ATB57791
City & State: Uusimaa
My Country: Suomi
Line Voltage: 230V
I'm a: Knowledge Seeker
Default Asus P6T Deluxe does not power on
Hi! I have a P6T Deluxe motherboard from Asus that does not power on at all. I tried to short the power on pins on the motherboard with a jumper and also tried the included power switch and neither of them does anything.
However, if I short the green and black wires from the ATX connector the motherboard powers up normally and even boots Windows 7.
I measured that the voltage between the PWR and ground pin is 3.3V when the motherboard is off and PSU connected.
Do you have any idea what is wrong with the motherboard or which components should I try to replace?
Pictures of the motherboard attached.
ATB57791 is offline   Reply With Quote
Old 07-01-2017, 02:29 AM   #2
Per Hansson
Per Hansson's Avatar
City & State: ----
My Country: Sweden
Line Voltage: 230v 50Hz
Default Re: Asus P6T Deluxe does not power on
Should not PWR_OK be 5v?
If so maybe it means the PSU itself is bad (or just it's PWR_OK signal).
Did you try another PSU?
__________________
Per Hansson is offline   Reply With Quote
Old 07-02-2017, 09:51 AM   #3
ATB57791
My Country: Suomi
Line Voltage: 230V
I have tested the motherboard with three known working PSUs.
I assume that the 3.3V stand by voltage comes from ME1117 voltage regulator. I measured the pads when 5VSB is fed to the motherboard and they looked OK in my opinion. The voltage on the other power button pin is 3.39V and the other one is ground.
The 5VSB voltage from psu is 5.00V. According to my knowledge the PWR_OK signal is only on when the PSU is on.
The problem here is that the motherboard does not start the PSU when I push the power button.
Old 07-02-2017, 10:18 AM   #4
Per Hansson
City & State: ----
My Country: Sweden
Yes, but 5VSB is not related to the PWR_OK signal.
Check the pinout here: http://pinouts.ru/Power/atx_v2_pinout.shtml
Old 07-02-2017, 10:26 AM   #5
ATB57791
My Country: Suomi
Line Voltage: 230V
I have not measured the PWR_OK signal. I meant that the pins on the motherboard that get shorted when you press the power button are 3.3V, sorry for being unclear. The PSU that I'm using is tested and working.
The motherboard starts only if I jump-start the power supply. So I am trying to find out why the motherboard does not short the PS_ON pin in the ATX connector when I push the power button.
Old 07-02-2017, 11:25 AM   #6
momaka
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
I'm a: Hobbyist Tech
The LPC Super IO chip is usually responsible for turning on the PSU.
On your board, the Super IO (SIO) should be that Winbond chip in the lower left corner. Can you post its part number? I can't seem to fully read it from your pictures. Looks like W83____HG-A
Around 3.3V on the Power Switch button on the motherboard is normal.
By the way, any chance the LAN chip gets hot when the PSU is plugged in the motherboard? A lot of times, a lightning strike can take out / damage the LAN chip, and sometimes also the SIO.
Old 07-02-2017, 01:18 PM   #7
ATB57791
My Country: Suomi
Line Voltage: 230V
The Super IO chip is Winbond W83667HG-A
Old 07-02-2017, 01:53 PM   #8
ATB57791
My Country: Suomi
Line Voltage: 230V
I booted the motherboard by jump starting the PSU. This time it took a few times until it booted successfully. Neither of the two Marvell's LAN chips (88E8056) were warm. The Marvell 88SE6320 SAS controller and 88SE6111 IDE controller were both a bit warm, but not too hot to touch. The Super IO chip was maybe just a little warm if not at all.
Old 07-04-2017, 08:21 PM   #9
momaka
momaka's Avatar
My Country: U.S.A.
Quote:
Welp...
I looked at its datasheet, and unfortunately, it looks like this Winbond chip does not control any of the motherboard's power functions.
... so whatever is controlling the power, it's not the Super IO. Might be the Southbridge then, unless you can trace the power switch header on the motherboard and see where the traces go. Perhaps there may be another chip just responsible for power functions.
Old 07-06-2017, 06:04 AM   #10
ScorpioMan86
City & State: Gauteng
My Country: South Africa
This might not be the case to your board but yesterday i had an MSI Z77A-G43 doing exactly the same, i shorted the psu, went into bios and updated it to the latest and after that it is all good to boot on its own, i dont know if it will help but there's no harm in trying
ScorpioMan86 is offline   Reply With Quote
Old 07-06-2017, 10:07 AM   #11
momaka
momaka's Avatar
My Country: U.S.A.
Quote:
Good point!
Actually now that you reminded me, we also had several board at work before that acted in a similar way. For those, however, they had socketed dual BIOSes. Switching to the other BIOS typically solved the issue.
So yes, try what ScorpioMan86 mentioned.
Old 07-06-2017, 01:50 PM   #12
ATB57791
My Country: Suomi
Line Voltage: 230V
The motherboard already had the newest bios (2209) installed so I downgraded the bios to 2101 but still it doesn't start on its own.
I also figured out why it didn't start with first try previously. I have to short the green and black wires on the ATX connector and also push the power button to start the motherboard.
I presume that the motherboard tries to start but somehow the circuit that would normally short the green and black wire doesn't work.
Edit: Also upgraded back to 2209 bios with no change.
Old 02-12-2018, 04:48 PM   #13
xinom
City & State: Krasnodar
My Country: Russia
There is another option (although it seems a bit late I saw the topic ...)
Close the green and black contacts with tweezers or wires, when the board starts up and displays information about the processor, memory, etc., close the power_on with tweezers or even for a second and the board should shut down (unless of course winbond did not die at all), then open the green and black contacts on the power supply connector and try to run as usual on power_on
On MSI boards, this operation helped to restore the normal start
xinom is offline   Reply With Quote
Old 02-12-2018, 10:26 PM   #14
Stefan Payne
City & State: Northern Germany
My Country: Germany
Line Voltage: 230VAC/50Hz or 400VAC/3P/50Hz
Quote:
Originally Posted by momaka View Post
Welp...
my guess would be that ASUS APU Chip next to the BIOS Chip.
Stefan Payne is offline   Reply With Quote
Old 02-13-2018, 04:02 PM   #15
piernov
City & State: Valbonne, 06
My Country: France
Power on is handled by the EC, the Winbond chip. Power states are handled by the southbridge, but the EC gives the initial startup signal (RSMRST then PWRBTN) to the southbridge.
Boardview of P6T attached if it helps.
__________________
OpenBoardview http://openboardview.org | IRC #openboardview@irc.freenode.net
piernov is offline   Reply With Quote
Old 02-14-2018, 02:24 PM   #16
emcee2
City & State: Vancouver, BC
My Country: Canada
Very good chance that one of the FET's under the skinny blue heatsink that is NOT connected to the heat pipe has gone bad.
emcee2 is offline   Reply With Quote
Old 06-06-2018, 11:43 AM   #17
ATB57791
My Country: Suomi
Line Voltage: 230V
I replaced the Super IO chip (W83667HG-A) on the motherboard and now it powers on normally. The power and reset buttons on the motherboard don't work, but it is not a big issue because the chassis power button is working.
Old 06-09-2018, 04:41 PM   #18
momaka
momaka's Avatar
My Country: U.S.A.
Awesome! Great to hear you got it sorted out and thanks for coming back to update us on the matter! I'm sure many others will find this info helpful too.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2019
Powered by vBulletin ®
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
