Recd this mobo unknown state.
Checked BIOS with my Willem. Find a Tiny OEM BIOS.
Suspect the mobo came out of a Tiny 5-5300 PCI-Express PC.
Had noticeable swollen cap beside PCI-Express slot - 10V 1000F.
Replaced with Panasonic FM 10V 1000uF.
This system is populated with;
4 of Green 1800 uF 16.0 V Sanyo WG 105 deg C - H 23.0 mm x Dia 10 mm
10 of Silver 560 uF 4.0 V Sanyo OSCON SEPC 105 deg C - H 10.0 mm x Dia 7.5 mm
12 of Black 1000 uF 10.0 V Elite PF(M) 105 deg C - H 16.0 mm x Dia 8.0 mm
4 of Purple 1000 uF 6.3 V Rubycon MBZ 105 deg C - H 16.0 mm x Dia 8.0 mm
4 of Brown 220 uF 16.0 V Teapo SEK 105 deg C - H 13.5 mm x Dia 5.0 mm
4 of Brown 470 uF 10.0 V Teapo SEK 105 deg C - H 13.5 mm x Dia 5.0 mm
2 of Black 680 uF 10.0 V Nichicon ZL 105 deg C - H 20.0 mm x Dia 7.5 mm
10 of Black 47 uF 16.0 V Teapo SS 105 deg C - H 10.0 mm x Dia 7.5 mm
Mobo powers up ok. Use a post card to get some readings.
All voltages appear ok - suspect the VRM (given the caps used) is not a problem.
The read out from the post card is;
+12V - good
-12V - good
-5V/3.3V - good
+5V - good
However, my POST diag card is flashing intermitently a number of indicators
including;
Sys Led - continuously flashing on/off
Clk Led - continuously flashing on/off, sometimes stays on for a second or two
IOW Led - flashing
Osc Frame - on
Rst - stays on
Bios Rdy - off
Data - continuously flashing on/off
The flashing behaviour is replicated on the Keyboard LEDS so far as;
1. The NUM lock;
2. The CAPS lock and;
3. The Scroll lock
keys flash in tandem with those flasing on/off LEDs on the POST card
As the reset is always on, there may well be a short to deal with.
Suspect crapacitor problems with DC-DC blocks on the board so far as
the first bad 10V 1000uF was Elite.
What are the views of forum members? Nuke the Elites, replace with FMs
+12V - good
-12V - good
-5V/3.3V - good
+5V - good
including;
IOW Led - flashing
Osc Frame - on
Rst - stays on
Bios Rdy - off
1. The NUM lock;
3. The Scroll lock
