Emachines T3256
    Re: Emachines T3256
    ya i think so too, FIC will send me 1 for $15 + shipping
      Re: Emachines T3256
      Well i performed a HOT FLASH and it worked I was able to hot flash it to the backup bios file i made befor flashing.
      But now im back to the original problum. The CPU only reads as a 1.2 and it is a AMD 2800+ witch should read earther 2.0 or 2.2 ( i dont remember witch core it is)
      The ram speed is showing at 333. How can i get the CPU to its full speed?? Is there a bios update out there?
      Thanks for all the help
        Re: Emachines T3256
        I could be wrong but I don't think that the speed reported in your bios controls the speed of the proc.
        That chip should be running at it's rated speed regaurdless of the bios missidentifying it.
        Run any benchmarking on it?
        Jim
          Re: Emachines T3256
          not yet, but the weard thing is it us to read the proper speed in the BIOS, post screen and in windows. I installed another stick of ram and its been like that ever since. I removed the new ram and it still reads wrong. Its very weard to me.
            Re: Emachines T3256
            have you sett the FSB of the CPU to 133 or 166MHZ /333 in the BIOS setup?
            Most mainboards are running at default on 100 or 133mhz, to reach the full speed you have to manually set this in the setup. Some older boards still require some jumper setting.
            E.g the K7S8x/e/+ boards all need the jumper seting to choose the right PCI/AGP divider, and then you coud use the biose to go further.
              Re: Emachines T3256
              A Hotflash! That can be very dangerous but I'm glad to see it worked for you Here's a link to the AU31 Manual
              There's a FSB jumper you need to switch. Diagram is on page 7.
                Re: Emachines T3256
                2Mb Flash EEPROM with Award BIOS
                - ACPI v2.0 compliant
                - S3 (Suspend to DRAM) sleep-state support
                - SMBIOS (System Management BIOS) v2.2 compliant
                - Supports Power failure recovery
                That's a lot of BIOS.
                Makes me wonder if the v2.2 thing allows to self recover?
                Jim
                  Re: Emachines T3256
                  gonzo0815,
                  Well this BIOs does not let you change ant CPU or Memory speeds or timings at all. The jumper if set to 133.
                  Mustang,
                  ya i dont like to hotflash(this ose my first time thow) but i figured i had nothing to lose. LOL
                    Re: Emachines T3256
                    Unless you don`t put the chip in the wrong side, there is no problem with hotflashing. Have this done with variouse devics without sever problem. The only thing was when i put the chip in with the false direction, the chip was getting so hot that the BIOS lable was melting. But anyway, the chip was not dead.
                    But any way, if you can`t set this in the bios setup, you have to flip the jumpers arround or your board is not kapable running at the required fsb.
                      Re: Emachines T3256
                      the motherboard os a 333FSB board. The jumper is on correct. It was running at he rated speed, i installed more ram and now its not at rated speed.
                        Re: Emachines T3256
                        I have a emachine T2865 . It is using AU31 motherboard. The minute I load optimal Bios settings and change jumper for a AMD XP 2.8 Cpu to run at 266mhz I get crash on startup and continual windows XP Startup loop! If I set jumper to 100mhz all runs fine except cpu only at 1252mhz instead of in the 2.2 range .
                          Re: Emachines T3256
                          does your ram support 266?
                          check out your psu too.
                            Re: Emachines T3256
                            Ram is 512mb DDR333 thats what came standard in this emachine! This is a typical emachine that had a bad power supply toasted motherboard friend was tossing so I figured it would be another project to play with ! Your probably right on power supply but i THINK IT MAY BE MOTHERBOARD CAPS! made mistake of buying another emachine motherboard on ebay. Guy had hundreds I think I know why!
                            Thanks!
                              Re: Emachines T3256
                              if it was wounded by the bestec blow em up psu its trash.
                              if there are bulging caps it might respond to a recap.
                              i too get lots of evilmachines mobos to rebuild and sell.
                              the am37 usually dies of bad bestec.
                              most have rubycon mbz caps.
                              imperial series about 50/50 bad caps/bestec.
