This info is reference material for others to find. This 2002 (7 year old) Soltek SL-KT600-RL motherboard started becoming unstable with random and increasingly frequency MS-Windows bugchecks. Decoding the bugchecks seemed to imply L2 cache errors. Further searching lead to the bad capacitor issue which visual inspection confirmed.
The Soltek SL-KT600-RL motherboard has:
* Qty 6 KZG (Chemicon?) 3300uF 6.3V 10mm caps
* Qty 3 KGZ (Chemicon?) 1500uF 16V 10mm caps
* Qty 9 OST 1000uF 6.3V 8mm caps
The six 3300uF caps are located under the heatsink and all six have bulging tops. The higher temperatures in this area probably did not do them any favor. The three 1500uF caps are located in the same area and visually appear ok. The nine 1000uF caps are scattered throughout the board and visually appear ok. There does not appear to be any damage or leakage from any caps.
Given the age of this board I'm replacing all of the above caps. Hopefully I'll know in a week or so if that was the only problem.
Great site - thanks for all the info.
