Hey guys I need Schematic for Toshiba Satellite P55 board VGST / VGSTG MB Rev 2.1. Friend of mine changed the screen without removing battery and one of the resistors next to LVDS cable is fried and there is no backlight. Thanks
Need Schematic Toshiba Satellite P55 VGST
Re: Need Schematic Toshiba Satellite P55 VGST
Originally posted by SuperAman View PostHey guys I need Schematic for Toshiba Satellite P55 board VGST / VGSTG MB Rev 2.1. Friend of mine changed the screen without removing battery and one of the resistors next to LVDS cable is fried and there is no backlight. ThanksNever stop LEARNING because life never stops TEACHING!
Originally posted by Duranitron View Postjust a suggestion. if you have collection of toshiba satellite schematics try to compare it to your board some different models are exactly the same from LVDS connection to the LCD. hope this helps.
just compare the board the LVDS pins and parts placements, if its exactly the same to your board likely its the same value.. just remove first the battery and power before repair. just be sure that the LCD replacement is the same value, product #like the original lcd or else it will not work or the resistor that burns will likely burn again.Never stop LEARNING because life never stops TEACHING!
Originally posted by Duranitron View Postjust compare the board the LVDS pins and parts placements, if its exactly the same to your board likely its the same value.. just remove first the battery and power before repair. just be sure that the LCD replacement is the same value, product #like the original lcd or else it will not work or the resistor that burns will likely burn again.
