Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > General Electronics Technical Discussion
Thread Tools Display Modes
Old 12-16-2018, 03:45 PM   #1
Widget
City & State: New South Wales
My Country: Australia
I'm a: Knowledge Seeker
Thumbs up Budget level ESR meter for beginner ?
Hi guys,
Bought one of these DIY ESR testers some time ago.
https://www.ebay.com.au/itm/Transist...JR7A:rk:7:pf:0
Didn't get around finishing it, ended up losing a couple of the parts (inc. the main MC); and rather than buying the replacement parts, figure it would better to just get another due to the price.
It's only a basic tester, but I did notice there were 2x kinds;
and
https://www.ebay.com.au/itm/DIY-SCR-...f06c:rk:1:pf:0
Similar in price, wondering if there were any differences that you guys know of?
Apart from that, is there a basic/budget alternative you would recommend ? Maybe one that can test parts in-circuit ?
Widget is offline   Reply With Quote
Old 12-16-2018, 04:10 PM   #2
dmill89
City & State: Harrisburg, PA
My Country: USA
Line Voltage: 120VAC 60Hz
Default Re: Budget level ESR meter for beginner ?
Quote:
Originally Posted by Widget View Post
Hi guys,
and
Functionality wise they are similar (at least the component testing part) and neither can test components in-circuit.
This one is a kit and uses "through-hole" components to allow easier assembly and also includes a basic square-wave generator: https://www.ebay.com.au/itm/Transist...JR7A:rk:7:pf:0
This one is pre-assembled and thus uses more compact surface-mount components, it also omits the square wave generator and is more-compact as a whole: https://www.ebay.com.au/itm/DIY-SCR-...f06c:rk:1:pf:0
dmill89 is offline   Reply With Quote
Old 12-16-2018, 07:30 PM   #3
Beau28713
City & State: Bryson City NC
My Country: United States
Line Voltage: 120Vac 60Hz
I'm a: Hobbyist Tech
I use the Bob Parker design Anatek blue ESR meter. Cost about $80 but works well for me.
Beau28713 is offline   Reply With Quote
Old 12-17-2018, 04:43 AM   #4
sam_sam_sam
City & State: Sunny Jacksonville FL
My Country: USA
Line Voltage: 120 Volts 60 HZ
I second this I have one also and quite often It has help me repair a lot of things
__________________
9 PC LCD Monitor
6 LCD Flat Screen TV
10 Desk Top Power Supply
1 Dell Mother Board
15 Computer Power Supply
1 Over Head Crane Current Sensing Board
All of these had CAPs POOF
sam_sam_sam is offline   Reply With Quote
Old 12-17-2018, 08:44 PM   #5
madan1
City & State: Sofia
My Country: Bulgaria
Quote:
Well, I have the red one and it has a "capacitor measuring" mode accessible from the menu.
Here is an extract from the manual
"The additional function "C+ESR@TP1-3" selects a stand-alone
capacity measurement with ESR (Equivalent Series Resistance)
measurement at the test pins TP1 and TP3. Capacities from 2uF
up to 50mF can be measured. Because the measurement voltage
is only about 300mV , in most cases the capacitor can be
measured "in circuit" without previous disassembling."
madan1 is offline   Reply With Quote
Old 12-21-2018, 05:34 AM   #6
Thedoc298
City & State: Union City
I have a few in all price range, but this one does really well and has a case and lot's of hidden features.
https://www.ebay.com/itm/2018-MK-328...72.m2749.l2649
Thedoc298 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2019
Powered by vBulletin ®
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
