Sorry for the long post, but I want to geive enough information....
Bought a non-working Epox KP6-BS (dual slot 1 board). Upon inspection, all of the 1200uf 6.3V caps were bulging at the #1 CPU slot. The caps at the #2 CPU slot looked fine. Also all of the 1000uf 10V caps by the MOFSETS looked bad also. Tayhem was the manufacturer of all the caps. I replaced all of the caps by the CPU slots (1200uf) , and by the MOFSETS (1000uf)
Unfortunately this did not resolve the issue. I am not 100% sure on how to check the MOFSETS, but I did notice that one of them appear to "open" when using an ohm meter. Input leg to output leg = inifinite resistance. FYI - this particular MOFSET was by the #1 CPU slot. The MOFSETS are still soldered to the board. The other MOFSET by the #2 CPU slot do not exhibit the same behavior while testing with an ohm meter.
Could the bad caps have blown the MOFSET? Any recommendations on where I can get a replacement? I tried to Google the part # D50N03A and nothing of value found. Other markings include K8 5A below the part number & a "M" on the casing. Also, has anyone ever been able to remove one of these from a motherboard? I had tried on a different motherboard in the past, and was never successful.
Thanks in advance.
Thanks in advance.
