HP Probook 450 G2 440 G2 LA-B181P BIOS + 470 G2
    Re: HP Probook 450 G2 440 G2 LA-B181P BIOS
    Hello!
    I have another HP Probook 450 G2 with bricked BIOS, MB model: LA-B181P Rev: 1.0 ZPL40/ZPL50/ZPL70. Can you fix my BIOS dump please?
    Sympoms are: then plug in power it turns on power button led for a moment, then power socket led flashes one time orange and shuts down.
      Originally posted by SMDFlea View Post
      Try this bios .
      thank fix dmi but problem with ati radeon R5 discrete, these bios for UMA intel
        Your bricked bios has M73 code, i made your new bios from a M73.bin .I just looked at the bios update on HP ,and it has M74 code,thats why the bios didn`t work. I`ll try to make another if i can find a good M74 dump .
          Heres another to try.If you can get it to boot up into windows then update the ME firmware
          https://ftp.hp.com/pub/softpaq/sp660...00/sp66390.exe
            Originally posted by sellit View Post
            Hello!
            Try this one.If you can get it to boot up into windows then update the ME firmware
              Thanks for help, but no changes, all the same symptoms, thinking maybe not BIOS fault, but something with MB.
                Try this one,if this bios doesn`t work you have other problems.
                  All the same, thank you for your help
                    Hello
                    I also have a Probook 450 G2, try HP Tools
                    Unfortunately updating the BIOS is not possible.
                    HP Bios Update and Recovery
                    1- Refresh
                    2- Create with USB flash drive for recovery.
                    At the start I press
                    Windows key and B key together
                    Screen stays dark and does not happen.
                    Can someone help me please how I can flash it.
                      thanks
                        tested working
                          thank you working
                            Originally posted by peste View Post
                            Hi
                            THANK U BRO
                              hi, i have a g2 450 laptop i tried all bioses here one of em worked and i got screen, but as soon as i put the parts together and turned on laptop again i have black screen and fan spins at full speed, after that i took all parts apart and i dont have display again till i reprogram the bios. it happens with its own back up bios too, can someone help me with this problem. thanks
                                thank you all for the help
                                  thanks
                                    Originally posted by ruslan657 View Post
                                    thank you working
                                    Thanks bro, work very fine on 440/450
                                      need clear me 470 g2 m73 with graphics
                                        post the original bios here
                                          I have a HP probook 470 G2 with a bricked bios. I flashed the bios file from post #1 and the notebook works again.
                                          Now I discovered that the AMD discrete graphics is missing. There should be a AMD R5 255M.
                                          Does someone have a bios dump with amd graphics? I attached my broken dump if it is useful.
