Old 07-18-2018, 02:56 PM   #1
sixstringartist
City & State: TX
Default CCFL wire insulator breaking down
https://imgur.com/a/yjEmFzT
The white spot here is where the wire insulation to the CCFLs has broken down. This monitor has a 2 second to black problem and I can see an arc for a second when powering up the monitor and the backlight is lit.
Is this a common failure pattern? Are there any component failures that are likely to be associated with a fault like this? Can I get by with wrapping the problematic area in electrical tape?
sixstringartist is offline   Reply With Quote
Old 07-18-2018, 03:05 PM   #2
goontron
5000!
goontron's Avatar
City & State: South Greeley, Wyoming
My Country: US
Line Voltage: 13.9kv HT service and some 240v center tap oddity.
Default Re: CCFL wire insulator breaking down
Not really, bad insulation, you can try.
Tomorrow Is Nearly Yesterday And Everyday Is Stupid!
goontron is offline   Reply With Quote
Old 07-18-2018, 04:41 PM   #3
petehall347
City & State: worcester
My Country: United Kingdom
i would spray it with insulator spray .. and separate the wires .
Old 07-18-2018, 09:05 PM   #4
sixstringartist
City & State: TX
Like this stuff? https://www.amazon.com/3M-Electrical.../dp/B074T4D93R
Old 07-18-2018, 09:29 PM   #5
R_J
City & State: ☻
My Country: Canada
A couple layers of electrical tape on both wires should work fine.
R_J is online now   Reply With Quote
Old 07-19-2018, 07:00 AM   #6
Andrew F. Ali
Andrew F. Ali's Avatar
City & State: Point Fortin
My Country: Trinidad & Tobago
Line Voltage: 125VAC 60Hz
If you have a piece of 3M Hi-voltage splicing rubber tape that would work as well>
Andrew F. Ali is offline   Reply With Quote
Old 07-19-2018, 08:19 AM   #7
petehall347
Originally Posted by sixstringartist View Post
yes .i use a clear one .
Old 07-19-2018, 08:43 AM   #8
vinceroger69
City & State: Nuneaton Warwickshire
My Country: uk
I'm a: Hobbyist Tech
can you remove that one wire out of the plug? (sometimes you can use a pin and press down on a lug and pull wire out of plug) then i would use some heat shrink tubing.
vinceroger69 is online now   Reply With Quote
Old 07-19-2018, 09:40 AM   #9
sixstringartist
City & State: TX
I probably could do that, Ive done similar work in the past and I have the heat shrink tubing. Is the tubing much of an insulator though? Ive always used it as a more professional looking ziptie.
Old 07-19-2018, 09:43 AM   #10
vinceroger69
My Country: uk
Im not 100% sure but i would add two layers on each wire if possible and i think it would work fine i would certainly try it myself if i had this issue.
Old 07-19-2018, 08:17 PM   #11
sixstringartist
City & State: TX
turns out at least 3 of the CCFL bulbs are toast. Fixing the cable is the least of my problems. Buying CCFLs online seems expensive. How to people normally replace these? Ditch the monitor? Pull from a donor? Thanks all for the responses.
Old 08-03-2018, 07:15 AM   #12
momaka
master hoarder
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
How did you determine that 3 (or more) of the CCFLs are bad? I think that's very very unlikely. They may be getting old and starting to pull more current, but it's very unlikely all 3 will fail at once.
As for the wire insulation: I suggest using at least several layers of electrical tape and then heat-shrink tubing on top. Most electrical tapes, if I remember correctly, are rated around 300-600V per insulating sheet/layer. So several layers should provide plenty of insulation. The reason I like to put heat-shrink tubing on top is because I often find that electrical tape tends to unwind/undo itself or just get loose and move around. The heat-shrink tubing will keep it all in one place.
Last but not least, as far as replacing CCFLs: if you have a donor monitor of the same size, that should work fine. I've bought discount bulbs before from CCFL warehouse, and they weren't too expensive ($5 per bulb with $5 shipping total). But they didn't come with wires, so I had to re-use the ones from the old bulbs, which is a bit more work - especially when it comes to making sure things are well-insulated. Otherwise, the more expensive bulbs should come with all leads/wires.
That said, what's the brand and model of this monitor, and how important is it to you? If it's just a standard 17/19" monitor, it's probably not worth going through all the hassle of replacing the CCFLs, unless you're doing it just for learning purposes. For bigger and/or some specialty application, it may be worthwhile doing. But again, that all depends on how much you value your time and what you're trying to achieve.
momaka is online now   Reply With Quote
