Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Laptops, Portable, and Mobile Devices
Thread Tools Display Modes
Old 03-25-2018, 07:29 PM   #1
Nitro468
City & State: Brooklyn
My Country: USA
I'm a: Knowledge Seeker
Default Snap On Verus Pro
OK something out of the box... Diagnostic scanner for cars that runs Windows XP. My tool guy got it on trade for a newer unit... Originally I was going to offer him something, it has a 4 channel lab scope built in.. It doesn't recognize the scope module (plugs into the rear of the unit), can also be run externally via USB cable.. It also has a wireless scan module ( you plug this into the cars OBDII port), it doesn't see that either...
The software crashed on him so he gave it to me to tinker with.. There is a recovery partition in it and I re imaged the unit.. Boots fine but doesn't see anything plugged into it...
I have plugged the scope and the scan module into a computer running windows, it does recognize both units.. The scan module must be synced via an USB cable once to become wireless...
Here is what I know...It has 2 USB ports, one is broken, see pics... Both ports have the 5V feed and ground on the outside terminals... Between pins 2 and 3 I get on port "A" 1.380 volts, port "B" .246 volts... Port "A" from ground to pin 2 .548V Pin 3 .299V Port "B" Pin From ground to pin 2 1.380V and Pin 3 0V..
Something is definitely up with the USB, any recommendations how to proceed ?
Nitro468 is offline   Reply With Quote
Old 03-26-2018, 12:52 AM   #2
caspian
City & State: Mainboard
My Country: Laptop
I'm a: Hobbyist Tech
Default Re: Snap On Verus Pro
check if the four pins of the broken USB port are shorted together or to ground.
caspian is offline   Reply With Quote
Old 03-26-2018, 06:27 PM   #3
Nitro468
My Country: USA
Quote:
Pins looked OK Might try to find the USB part and change that for a start...Looked fine with a 30X loupe
Old 03-27-2018, 02:14 AM   #4
caspian
My Country: Laptop
measure resistance to Ground on each pin.
Old 03-31-2018, 11:59 AM   #5
Nitro468
My Country: USA
Over 100K Ω each....
Old 04-01-2018, 08:52 AM   #6
caspian
My Country: Laptop
I hope this board gets fixed by USB connector replacement. If not so, a number of tests should be done. Since there is no schematics available, fixing it may get really difficult and time consuming. After this replacement, test a USB flash drive on these ports.
When you connect the scope or the scan module to another computer, does it show an unknown device or it does no reaction to this connection?
Old 04-01-2018, 05:45 PM   #7
Nitro468
My Country: USA
Is this a USB chip... Traced several pins from the USB to here... Too many to be coincidence...
Old 04-01-2018, 04:40 PM   #8
Nitro468
My Country: USA
Other computers see the connections, unknown device, no drivers loaded.. They seem to have some function... I plugged a USB mouse in the Verus, no response...
Old 04-01-2018, 05:06 PM   #9
Nitro468
My Country: USA
Any common USB chips to look for ?
Old 04-02-2018, 03:10 AM   #10
caspian
My Country: Laptop
This IC seems to be an RS232 controller. what is the model of the IC? the datasheet says what it is for.
Check where pin 2 and 3 of the USB connector are connected to.
Old 04-07-2018, 04:03 PM   #11
Nitro468
My Country: USA
F81216D/DG https://www.dfi-itox.com/pages/support/wdt/F81216.pdf
Old 04-07-2018, 04:52 PM   #12
caspian
My Country: Laptop
U6 does not seem to be a USB controller. Now check U7 and find its model. It can not be read from the photos.
Old 04-09-2018, 08:07 PM   #13
Nitro468
My Country: USA
U7 alc886 Realtek audio chip.... Guess I'll keep looking...LOL
Old 04-10-2018, 12:25 AM   #14
caspian
My Country: Laptop
it is also possible that the big green chip controls the USB itself.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2020
Powered by vBulletin ®
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
