It originally starts with green flashing light then it has backlight maybe lower region just but it's less than second then continuous red flashing light 3/4 seconds apart it lasts as long as I leave the set on.
Panasonic TX55DX600b Continuous red lights 3 seconds apart
Re: Panasonic TX55DX600b Continuous red lights 3 seconds apart
Originally posted by nomoresonys View PostWith tv unplugged from power, unhook cable from powerboard to mainboard, plug tv into power, see if backlight comes on and stays on.
Check the voltage going to the two led strings on the power supply, test points SRV-led1 & SRV-led2, monitor the point and turn on the tv and note the voltage.
How many wires are on each plug going to the leds? You may need to test the voltage on each wire going to the backlights to get a better idea of the problem.
Post pictures of the board and the plug going to the led'sLast edited by R_J; 08-22-2019, 05:38 PM.
Originally posted by R_J View PostCheck the voltage going to the two led strings on the power supply, test points SRV-led1 & SRV-led2, monitor the point and turn on the tv and note the voltage.
Also I hear a clicking coming from approximately the area circled hard to tell exactly.
Also whether I press power on or off it dosn't change Noether does the clickingLast edited by Fixing222; 08-22-2019, 05:52 PM.
It looks like you have 8 strings of LED, 4 strings per LED drivers, there are two LED drivers.
The SRV_LED 1 and 2 are for feeding the Voltages to the Anodes of the LED strings.
With black probe on chassis and red probe on The SRV_LED 1, what do you see on the meter when you turn on the TV? Same for SRV_LED 2.Never stop learning
Originally posted by budm View PostIt looks like you have 8 strings of LED, 4 strings per LED drivers, there are two LED drivers.
With black probe on chassis and red probe on The SRV_LED 1, what do you see on the meter when you turn on the TV? Same for SRV_LED 2.Last edited by Fixing222; 08-22-2019, 06:06 PM.
I am asking for the Voltage reading when the TV is turned on at the jumper/test pint SRV_LED 1 and SRV_LED 2, only two test points I am asking for.Never stop learning
Originally posted by budm View PostI am asking for the Voltage reading when the TV is turned on at the jumper/test pint SRV_LED 1 and SRV_LED 2, only two test points I am asking for.
How do I know if it's just one strip is that usually the case when only one returned no lights and I bet there are no replacement ones now also
Edit seen replacement strips.Last edited by Fixing222; 08-22-2019, 07:41 PM.
Is it likely one strip of bad LED's causing this may I have to replace more than one strip and is it likely to work in the case of I replace the led strip?Last edited by Fixing222; 08-22-2019, 07:43 PM.
Ok to update I took of the panel as I had to anyway and did tests in the strips and found one did not light so I have ordered a replacement.
Does anyone know of it sometimes a led going can damaged a power supply or is that rare?
They just drive the LED's very hard so they do not last, make sure to turn down the backlights level for all inputs to as low as possible to extend the life of the LED's.Never stop learning
Originally posted by budm View PostThey just drive the LED's very hard so they do not last, make sure to turn down the backlights level for all inputs to as low as possible to extend the life of the LED's.
But regularly i always put on low for my eye health and avoid headaches and recently i learned it helps the TV too so will do thanks.
Originally posted by budm View PostThey just drive the LED's very hard so they do not last, make sure to turn down the backlights level for all inputs to as low as possible to extend the life of the LED's.Last edited by Fixing222; 08-30-2019, 06:11 PM.
Thanks for the follow-up on the repair.Never stop learning
