Hello can you help elitebook 8760W laptop which has a problem with charging
    Re: Hello can you help elitebook 8760W laptop which has a problem with charging
    Originally posted by mcplslg123 View Post
    ACDET signal. It should'nt be 6V. may be approx 2.6V. ReGN should be 6V instead.
    Yep, sorry my bad.
    ACDET ~2.6V
    REGN = 6V
    @mohammed mohan, confirm if this schematic match your motherboard reference. Link also has boardview. https://www.badcaps.net/forum/showthread.php?t=22188
      Originally posted by lapfix View Post
      Even this update you stil got a lot of problems , so Voltage of the first 2 mosfet all pins ( S/D/G ).
      If you have schematic post it here
      Hello
      I apologize for all the above. The pins were incorrectly calculated
      Because I am a little tired, I measured it again, and in sequence, please help me in the solution
      Pin voltage
      1 = 19.63
      2 = 19.63
      3 = 19.57
      4 = 25.71
      5 = 3.349
      6 = 2.671
      7 = 0
      8 = 3.369
      9 = 3.367
      10 = 3.356
      11 = 0.302
      12 = 0
      13 = 0
      14 = 0
      15 = 0
      16 = 6.039
      17 = 5.860
      18 = 0
      19 = 0
      20 = 17.05
      qayyum786 is offline Report Post
      Mohammed Mohan
        Originally posted by mohammed mohan
        Hello
        Because I am a little tired, I measured it without a battery again, and in the sequence, please help me in the solution
        Pin voltage
        1 = 19.63
        2 = 19.63
        3 = 19.57
        4 = 25.71
        5 = 3.349
        6 = 2.671
        7 = 0
        8 = 3.369
        9 = 3.367
        10 = 3.356
        11 = 0.302
        12 = 0
        13 = 0
        14 = 0
        15 = 0
        16 = 6.039
        17 = 5.860
        18 = 0
        19 = 0
        20 = 17.05
        qayyum786 is offline Report Postport Post
        Is battery connected to laptop when you took these measurement?
          My friend, you are not answering the questions. You are only re-posting the same thing over and over again! Replying only once is enough, no need to reply each member the same thing.
          If you want us to be able to help you, answer the questions that were asked.
            The measurements you made without battery
            Mohammed Mohan
              When the battery is NOT connected, what is the voltage on + of battery connector?
              Measure the voltage again with the battery connected (Connect AC adapter AND Battery)
                With battery 0.022
                Without a battery 0.00
                Mohammed Mohan
                  Originally posted by mohammed mohan View Post
                  With battery 0.022
                  Check if Q15 and Q16 is good (check continuity).
                  If it is OK, connect BOTH AC adapter AND Battery and measure the voltage again:
                  Pin voltage
                  1 = ?
                  2 = ?
                  3 = ?
                  4 = ?
                  5 = ?
                  6 = ?
                  7 = ?
                  8 = ?
                  9 = ?
                  10 = ?
                  11 = ?
                  12 = ?
                  13 = ?
                  14 = ?
                  15 = ?
                  16 = ?
                  17 = ?
                  18 = ?
                  19 = ?
                  20 = ?
                    Check with the battery adapter AC
                    With picture attached Q15 & Q16 check
                    Pin voltage
                    1 = 19.06
                    2 = 19.06
                    3 = 19.41
                    4 = 19.41
                    5 = 3.341
                    6 = 2.671
                    7 = 0
                    8 = 3.360
                    9 = 3.360
                    10 = 3.348
                    11 = 0.147
                    12 = 0
                    13 = 0
                    14 = 0
                    15 = 0
                    16 = 6.038
                    17 = 5.841
                    18 = 0
                    19 = 0
                    20 = 18.33
                    Mohammed Mohan
                      Check mosfet with both battery and AC adapter. From your attached picture, battery is not connected.
                        The battery is connected and gives in charge
                        But the percentage does not increase. It remains 0. I tried another battery. It remains 0
                        Mohammed Mohan
                          I have not solved the problem yet, can you help?
                          Mohammed Mohan
