Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Game Consoles & Other Weird Devices
Thread Tools Display Modes
Old 05-21-2020, 04:36 AM   #1
dicky96
dicky96's Avatar
City & State: Sunny Gran Canaria
My Country: Spain
Line Voltage: 220V 50Hz
I'm a: Professional Tech
Default HDD Spins up and down again at power on
Hi guys. I hope this is the correct forum section
One of my 2TB internal Hard Drives has given up the ghost. It is a Seagate Desktop HDD ST2000DM001
It was working fine, it has not been dropped or subject to shock. Basically i was copying a load of files from another drive when it suddenly just hung up. The PC was still running but the progress bar did not move for a long time. I cancelled the copy operation and restarted the PC
I checked some of the copied files were OK (video files, they played fine) and then started to copy about another 20Gb of files. They copied OK though at one point the progress seemed to stop, then started again.
I checked those newly copied files by playing one of them. After a few minutes the video just froze (in VLC) and I had to shut the the PC down by holding the power button in because I could not bring the task manager to the front of VLC even though the windows itself had not crashed. After that the PC took a longer than normal time to load Windows 10 and the HDD was not found.
I tried running Testdisk and it sees the drive but as 130GB or something like that, not 2TB. The BIOS does not detect the drive at all.
I could not hear the drive spinning (though it possibly had already spun up and down because I didin't know about that yet) so I removed the drive controller pcb and the little contacts between the drive and the PCB were quite corroded so I cleaned them
After that I reconnected. The drive spins up sounding normal, I hear a few of clicks/clunks (not loud I have to hold the drive to my ear) then it spins back down again. This happens even if I just connect SATA power and not the data cable. It does not spin up again until I power off and on.
Any suggestions how to get that back?
dicky96 is offline   Reply With Quote
Old 05-21-2020, 05:11 PM   #2
RJARRRPCGP
City & State: North Springfield, Vermont
My Country: USA
Line Voltage: 118-127V 59-63.5 Hz-> actualizo: pérdido de voltaje
I'm a: Knowledge Seeker
Default Re: HDD Spins up and down again at power on
Sounds more like classic HDD failure, initially. But I wonder about board connections with that spin-down BS...
__________________
Asus P6T6 WS Revolution
Core i7 Extreme "Bloomfield" 965
Asus Strix GeForce GTX 970
Windows 7 SP1
SoundBlaster ZXR
Corsair TX850M PSU
Looks like I have a laptop that kills a desktop PC!
Received on November 4, 2019:
MSI GF63 Thin 9SC-649US
"Don't eat yellow snow!" -Salem
RJARRRPCGP is offline   Reply With Quote
Old 05-21-2020, 06:39 PM   #3
redwire
City & State: Alberta
My Country: Canada
Recheck your work cleaning the head connections, you seem to have made it worse? The copper gets oxidized and maybe you don't have the spring pressure. You have to clean both ends.
The drive spins up and reads its firmware off the platter, so if that isn't happening- I think it gives up and then shuts off the motor.
That Seagate HDD (line) is notoriously a lemon, across the internet many complaints.
redwire is offline   Reply With Quote
Old 05-22-2020, 04:40 PM   #4
CapLeaker
Leaking Member
CapLeaker's Avatar
City & State: Atlantic Canada
My Country: Canada
Line Voltage: Ground, 0Hz
I'm a: Hobbyist Tech
remove the controller board again again and recheck your work
CapLeaker is offline   Reply With Quote
Old 05-23-2020, 04:22 AM   #5
SMDFlea
Moderator
City & State: York
My Country: UK
Connect the drive up to a board with sata 2 and see if it spins up,disable s.m.a.r.t ,and set ide/sata to compatibility.The drive has bad sectors and/or a partition problem.
SMDFlea is offline   Reply With Quote
Old 05-24-2020, 10:15 PM   #6
momaka
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
Sorry! It's dead, Jim.
I got two of these 2TB ST2000DM001 from a box at work that was going to get scrapped. Initially, I was very excited, because I have found some good working HDDs in the past in that box (only about 1/5 of the drives, though.) Anyways, the first ST2000DM001 HDD I found shows no issues in SMART, but is laggy and sometimes clicks in a strange way when HDD is spinning up and calibrating. Probably will fail. I don't remember if HDTune could complete a surface test on that one or not
The other ST2000DM001: clicks and spins down the same was yours (though on mine, the clicks are rather loud. I think it's just either bad head [wear] or bad media that causes these to die so quickly.
momaka is online now   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2020
Powered by vBulletin ®
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
