Need help with this TV. I am wondering if anyone has seen this problem before. I have the above listed TV. Will not turn on. Here is what I have tried.
I am out of ideas here. When I plug the power in the standby light flashes 6 times. Nothing will turn on the set. I tried issuing the reset command via the remote. (standby light flashes when I press the remote buttons.) I have checked the other posts here and the symptoms don't fit. Attached are pictures of the new main board (green), old main board (blue), and power supply. Any advice is appreciated.
- Check Power supply voltages(13V is at ~ 12.8, 5v is at ~ 5.2)
- Unplug main board (TV back light comes on)
- Replace main board (still has the same symptoms)
- Unplugged Tcon (still has the same symptoms)
