Lenovo G50-70 - power on problem
    Re: Lenovo G50-70 - power on problem
    Originally posted by DeniS182 View Post
    PQ204 And PU1208 aren't on pcb.
    Yes, my mistake .
      I can't find problem, have someone any idea? Thanks
        I feel your IT8586E is either not properly soldered, or bad flash or the chip itself is bad. Remember, whatever we order online, these chips are not new(majority case). So i'll suggest before discarding this particular case if you another ite8586, try it once. I had similar problems and ultimately the so called new ite chip was bad. You never know with these cheap chinese stuff....
          It could be the KBC as suggested by mcplslg123 ,try this before replacing it though,Check everything on ADAPTER_ID_ON# ,PR322 voltage on both pins ,PC1266, PD304, PQ995 if they`re on the board ...
            IT8586 is soldered properly, I also mean my problem is in bad flash or chip itself. I need to buy programmer and then try it with other chip.
            SMDFlea: these components aren't on board
              You said at the outset that you replaced IT8586. If you dont have programmer for kbc, how do you programmed it?? Without programming it wont work
                Sorry denis, i re-read your post-it was programmed chip.
                  Today I reprogramm KB controller and laptop is now on, but with no picture, only black screen. I don't have voltage on +VGA_CORE, on gates of mosfets also and PIN 8 ENABLE signal on ISL62771HRTZ should be 3.3V? because I have zero here. I attached right schematic for NM-A271.
                    Is PXS_PWREN even coming from PCH? (MCP in schematic DDI, EDP section) There are many places where it goes....
                    while alive { live(toFullest=true) }
                      I inject 3.3V to 8pin enable and I have 1V on vga_core but still black screen.
                      +0.95VSP_VGA and +1.8VSP_VGA/1A are here.
                        And you get VGA_PWRGD signal at EC? When you inject?
                          yes pin 85 EC - 3V
                            @DeniS182 Uhm... I'm busy here with a HP board giving me random start/not working shit... so my mind is fluttered with shit atm but uhm... Did you make sure that you have the suspected powerup states. See page/sheet 18
                              Did you flash a good bios with clean ME ,does the fan spin .
                                I tried two dumps I don't know if ME is clean or not. Fan spin 1sec after laptop power on and after few seconds spin normally.
                                  Post your original bios backup if you have it.It has your DMI info/win key .
                                    I attached my backup of bios
                                      try this bios and ec.,latest versions.If it doesn`t work its back to more testing.
                                        I flashed main and ec bios. Now led and fan only spin for 1 second, then turns off and again, again.. it's turning on and off.
                                          I removed PJ702 now motherboard have vga_core voltage without injection, led is still on, fan not spinning. Before PJ702 I have 1.05VS, after PJ702 there isn't short, this rail only have 90-100mA current consumtion.
