Toshiba 37bv701b No sound
    Re: Toshiba 37bv701b No sound
    Turn the TV on.
    * Press and hold the {VOL-} button on the TV.
    * Press and hold the {9} button on the remote.
    * The Service Menu will be displayed.
    * Use the {CH+} or {CH-} buttons to select the item.
    * Use the {VOL+} and {VOL -} buttons to adjust the value.
    * Turn the set off to exit the Service Menu.
      Thank you! I'm visiting my friend in couple of days so will try them out.
        +1 for the standard menu factory reset - worked on a 5yo set with very little use, let's see if it lasts
          In case the remote is missing it's possible to replicate commands using some other means like arduino.
          The IR receiver on these uses RC5 protocol. There are two hex values meaning they both work for the same command.
          Code:
          00, 01 0
          02, 03 1
          04, 05 2
          06, 07 3
          08, 09 4
          0a, 0b 5
          0c, 0d 6
          0e, 0f 7
          10, 11 8
          12, 13 9
          14, 15 BACK (return/exit)
          16, 17 SCREEN (image size)
          18, 19 POWER
          1A, 1B MUTE
          1C, 1D PRESET (picture)
          1E, 1F LANG
          20, 21 VOL+
          22, 23 VOL-
          24, 25 INFO
          26, 27 DOWN
          28, 29 UP
          2a, 2b LEFT
          2c, 2d RIGHT
          3e, 3f Subtitle
          40, 41 Channel +
          42, 43 Channel -
          44, 45 LAST (return to previous program)
          50, 51 FAV
          54, 55 SLEEP
          5c, 5d PIP
          5e, 5f EPG ??
          64, 65 YELLOW
          68, 69 BLUE
          60, 61 MENU
          6a, 6b OK
          6c, 6d GREEN
          6e, 6f RED
          70, 71 SOURCE
          78, 79 TEXT
            Service manual.
